LS7 valves/springs/pushrod length??
Old Oct 11, 2005 | 08:32 PM
Greg Fell's Avatar
Default LS7 valves/springs/pushrod length??
Has anyone got any idea's yet on stainless valves, and 'good' springs that will allow me to run a big cam? I believe the installed height is 1.980 vs 1.800 in the ls1/6 heads. The valves are 2.20 x 1.610 I believe, but are also longer.
Also, any guesses as to pushrod length?
Old Oct 12, 2005 | 09:08 AM
JC5's Avatar
JC5
call Cary or Craig at ET Performance
Old Oct 12, 2005 | 09:39 AM
Ferocity02's Avatar
Let us know what you find out! Thanks Greg.
Old Oct 12, 2005 | 04:05 PM
Badls6SS's Avatar
I Work At A Chevy Dealership And Called An Enginer At Detroit And Was Told That The Push Rod Length Is The Same As An Ls1
Old Oct 12, 2005 | 04:26 PM
Greg Fell's Avatar
Hmmm, I was told different. The installed height is different. The valves are longer. The intakes are offset. Dunno, I'd be surprised.
Old Oct 12, 2005 | 07:49 PM
Badls6SS's Avatar
I was talking to him today and i was told they are the same length. The offset is done in the rocker so the push rod and lifter are in the same position as any Gen 3- Gen 4.
He is calling me back tommorow and i will double check. Also the reason he is calling me back is to hopefully give me some flow #s on the heads.
Old Oct 13, 2005 | 02:02 PM
Greg Fell's Avatar
Cool, well let us know on the flow numbers.
I will have to mill .048 probably to get CR where I want it...so the p-rods may be 7.350 then.
Old Oct 31, 2005 | 02:20 PM
Greg Fell's Avatar
Part number for the LS7 pushrod 12593344
Longer than ls1/6
Old Oct 31, 2005 | 03:44 PM
Ferocity02's Avatar
Whats the length on the LS7 pushrods? Might be worthwhile to buy some aftermarket hardened rods.
Old Oct 31, 2005 | 10:27 PM
Louis's Avatar
Ill measure a pushrod tomorrow guys They are different.
Old Nov 3, 2005 | 04:30 PM
Louis's Avatar
they are about 7.7x in length
I cant find my 12" dial caliper. Its hiding from me
Old Nov 3, 2005 | 05:34 PM
vettenuts's Avatar
See if you can get the weight of the titanium valves from him as well.
Old Nov 3, 2005 | 08:14 PM
Gary Z's Avatar
According to More Performance new 3/8 OD Pushrod is 7.820 Long
