Just ordered my 408!! What Cam?
With Wiseco's Off-The-Shelf 408 LS1 piston and a 6.0L GM MLS gasket the chamber volume needs to be 66CC's for 11:1 compression. That is what we've ordered.
The other set of 240CC heads that we used flowed 336 @ .600 on a 4.000" bore. They went on a 382 that made 470 RWHP with a grandma cam. We're going to add a FAST 90/90 and some Kooks 1 7/8th headers and try to make 500 RWHP with his wife-loving cam (Think stock cubic-inch sized cam). On a 4.030" bore they will go over 340 for sure. I wouldn't even be supprised to see 350 @ .650. Craig said we should see the heads in about 3 weeks.
The cam will probably be in the low/mid 240's @ .050 for intake duration. With David's bolt-ons I'm expecting to see 530 RWHP through his A4. On his 200 shot 750 would be a nice number don't you think David?
Levi, these heads sell for $2,650 fully assembled and ready to run. PM me if you're interested.
Sounds like you'll have a sweet set-up to.
I also went with the 454 so I could use the old SS/454 badges on the side. I may look into putting some 454 badges on the cowling of th eSS hood to. The heads are ET Performance 245CC 11* Heads. They have 2.080/1.600 Valves, REV Stainless Steel Valves, Manley Valvesprings, Locks, and Retainers, good to .650" lift. Combustion Chamber size is 64cc's. Compression will be exactly 11.3:1 using the stock GM 6.0L MLS Headgasket.
This is what the set-up looks like, with all the stuff I have in my sig to go with it. Will be bumping the shot to a 200!!!!!
__________________
With a 408, if you are willing to sacrifice some bottom end, you probably could go even bigger. 250/260 range. If you are willing to live with the loppy high idle, you could move the LSA all the way down to 106 or so to get some dynamic compression back.
The hydraulic lifter cars use much smaller cams than the solid lifer engines. If you are hydraulic, why not an LSK lobe, at least on the intake. It will maximize your curtain area, complementing you heads.
If you are going solid, well, you can get pretty radical.
Mr. Beast96Z, it sounds like you will have a gorgeous motor. How are you handling the ECU without a MAF? How high do you expect to rev it? And I would love to hear about your throttle response when you get it, which may be surgically precise
