cam specs on LS7??
Old Dec 15, 2005 | 05:39 PM
NickcZ28's Avatar
Default cam specs on LS7??
Anyone know the specs?? Just curious??
Old Dec 15, 2005 | 08:49 PM
Bill Reid's Avatar
I'll know in a few days... I have one getting cam doctored. Unless someone beats me to it I'll post the info up when I get it...
Bill
Old Dec 15, 2005 | 09:38 PM
John B's Avatar
Moderator
Awesome Bill! Just what I wanted to know too....especially the 0.006" values so that we can determine the DCR.
The basic spec @ 0.050" is 211°/230° with the total lift after rocker ratio 0.591"
Old Dec 16, 2005 | 09:27 AM
NickcZ28's Avatar
Will it fit into an LS1??
Old Dec 16, 2005 | 11:41 AM
Bill Reid's Avatar
Cam sensor trigger is not on the cam... I suppose if you use an early LS2 cam sprocket and front cover/sensor assembly with an adaptor harness you could... along with a set of 1.8 rockers to maintain the lift specs.
Bill
Old Dec 16, 2005 | 12:16 PM
NickcZ28's Avatar
Damn thats alot of work...
Old Dec 16, 2005 | 01:00 PM
S1LV3R's Avatar
Once you get the specs, just have it ground on a traditional ls1 cam blank. Problem solved
How will this cam sound in a motor with smaller displacement (346)
Old Dec 16, 2005 | 04:17 PM
Project GatTagO's Avatar
There is way more to grinding a cam then just getting the right "specs". There are things like opening and closing ramps and valve acceleration rates that vary dramatically from cam company to cam company. GM lobes much gentler then aftermarket lobes, since they ahve to pass stringent durability tests. THe aftermarket is not concerned about that, they make parts for more power.
Andrew
Old Dec 16, 2005 | 07:30 PM
gto69judge's Avatar
Default LS7 Cam Specs
211/230 120 LSA 123 ICL are the specs I heard. Hope this helps.
Old Dec 16, 2005 | 10:04 PM
S1LV3R's Avatar
Andrew
Are you saying once they get the specs from the cam doctor they can't tell how steep the ramps are on the lobes? If that's the case then what is the purpose of using it. I would imagine all they would need to grind a new cam would be the "specs" from the cam doctor.
Are you trying to say the cam companys are only going to use their lobes?
If you read the 2nd post, maybe you would understand that when I say specs they are a little more specific than just saying 211/230 or just throwing #'s out there.
