LS7 head swap ?
Old Dec 24, 2005 | 11:22 AM
GTFORMULA's Avatar
Default LS7 head swap ?
What all is involved from you guys that have done it and what kind of results have you had, thanks i appreciate any info
Old Dec 26, 2005 | 11:41 AM
GTFORMULA's Avatar
Anybody?
Old Dec 26, 2005 | 01:08 PM
MrEracer's Avatar
I'm still looking for valves and rocker arms for mine...
Shirl Dickey
Old Dec 26, 2005 | 01:32 PM
C_Williams's Avatar
Originally Posted by GTFORMULA
Anybody?
We are doing the swap in the coming two weeks as long as we find a suitable spring.
Old Dec 26, 2005 | 01:42 PM
GTFORMULA's Avatar
AandA I know your very good at everything plese tell me what parts you needed and what the results are when your done. Prices to please. thanks
Old Dec 27, 2005 | 11:49 AM
Greg Fell's Avatar
I also am waiting for rockers/valves. The springs I'm going to use are cam motion k-motion k-800's, in conjunction with the morel lifters as the spring pressure is probably a bit high for a stock lifter.
1.460" O.D. 1.085" Coil Bind #165 closed (1.850") 470# open (1.150")
Best part, they are $120!!
Old Dec 27, 2005 | 06:18 PM
GTFORMULA's Avatar
keep it comin guys, any info is good
Old Dec 29, 2005 | 10:52 AM
GTFORMULA's Avatar
to the top
Old Dec 29, 2005 | 10:59 AM
Ferocity02's Avatar
Things you will need for LS7 head swap...
-Block with larger bore
-Pair of GM LS7 heads
-GM LS7 intake manifold
-GM LS7 fuel rail
-New head gaskets
-Valves, either GM ones($$$) or stainless(heavy)
-Springs, preferably aftermarket, big if using stainless valves
-GM LS7 rocker arms
-New pushrods, probably longer than LS1/6
-90mm TB with a magical way to mount it onto the manifold
-Retainers, locks, seals for valves and valve springs
-New lifters, if using a BIG valve spring
Anything else I am missing?
Old Dec 29, 2005 | 11:25 AM
GTFORMULA's Avatar
keep it coming everybody, does anyone know when the heads will be sold complete
Old Dec 29, 2005 | 12:01 PM
Bill Reid's Avatar
-GM LS7 fuel rail
-New head gaskets
-GM LS7 rocker arms
- Pistons that can handle the 12 degree valve angle.
- If using GM Ti intake valve you'll need the lash caps.
Aren't the LS2 and LS7 TB's the same? I haven't checked our project motor but from a quick glance they sure look the same.
The LS7 lifters are a new and improved design... no one knows of their limitations yet.
Regarding retainers locks and springs... our project LS7 crate motor heads will not be disassembled so I cannot give specific set up differences. What I do know from plain sight is the factory Ti retainers are offset higher in relation to the locks. In other words the locks sit in a deeper pocket. Hot Rod magazine states the LS7 specific retainers were designed to prevent coil bind with the higher lift LS7 cam coupled with the 1.8 rockers. So, a lower seat pressure but apparantly it works. If you were to look at an assembled LS7 head versus, say, an assembled LS6 head you would see there is alot more valve stem exposed above the retainer/locks. I wonder if the factory LS7 valves are longer... and if so... that would mean folks would need to stick with LS7 specific length valves even if they are aftermarket.
Just a few thoughts based on what I see...
What would be really cool is someone who really knows what they are talking about share with us regarding specific differences in LS1/6/2 and LS7 valvetrain geometry... what can and cannot be swapped back and forth...
Bill
Old Dec 29, 2005 | 12:28 PM
Greg Fell's Avatar
I just looked, and the manifold has 4 mounting holes, and so does my TB...its a NW 90 mm. The LS2 and LS7 TB's are the same part number, I believe.
I believe the LS7 pushrod length is 8.4"...confound it I cannot remember. It is much bigger than an LS1/6. My pushrod length checker isn't even long enough!
I would agree that this is ideal...however I don't necessarily think having 15* pistons cut for a 2.10 will be a showstopper. Obviously, you cannot run as large of cam as you could with 12* 2.20 flycut pistons. I plan on running a 243/250 114+2 .655/.666, which should help with some PtoV clearance, compared to my existing 248/248 110+2 .621/.621. Can always flycut the pistons yourself too.
Old Dec 29, 2005 | 12:32 PM
Ferocity02's Avatar
Yes, the LS2 and LS7 TB's are the same. But I havent seen anyone mount a NW TB to the LS7 manifold yet. Someone did but had problems with cable interferance or something.
Old Dec 29, 2005 | 12:34 PM
Greg Fell's Avatar
Ah, well I drive a vette, so I have drive-by-wire. This could definately be an issue with an f-body.
Old Dec 29, 2005 | 04:24 PM
phantom meneSS's Avatar
I've done it. I used the SDPC cable mount but still needed to shorten the throttle cable about 25mm. It is a straight forward procedure much like a LS2 manifold swap except the SDPC cable mount braket needed to be linished to clear the map sensor and the large body injectors and the fuel rail mounting brakets had to be redesigned as they are differant to LS2. I used a Fast 90mm TB.
Matt.
Old Dec 30, 2005 | 01:38 PM
GTFORMULA's Avatar
will SDPC be making a cable bracket specifically for the ls7 intake with cable driven throttle body.
Old Dec 31, 2005 | 11:25 AM
ace68's Avatar
What is the min. boar req. for the ls7 heads?
Old Dec 31, 2005 | 11:53 AM
GTFORMULA's Avatar
I have heard 4.060, but I would look more to confirm.
