90mm Cable TB on an LS7 Manifold... Anyone Accomplished This?
#61
dont all the TPI and LT1's open with the Top going forward and bottom going in?? the must have changed it for the LS1.. then went back to it for the LS2.. interesting..
i just went outside.. took off the air tube to my LT1 powered thirdgen... top of the blade opens forward.. because the cable is attached to the bottom of the arm and pulls back.. looks like these LS1's wrap over the top and pull back.. so why not just flip the design? it shouldnt be too hard to do..
#62
Originally Posted by 427
The problem here only relates to the LS7 intake with early tb's that open top first. If you look at the picture you can see the port entry for cyl 2 right behind the tb mounting flange. If the tb opens top in, there will be a problem with dist inside the intake.
Kurt
Kurt
With stock cam shafts disribution through out the load range is pretty good.
The minute you put a larger cam in you really upset the dynamics of the intake. You will see up to two and sometimes almost three a/fs cyl to cyl
With large cams the a/f spread is still evident at wot through out the rpm range although to a much smaller degree. So to answer the question of which way is better for the throttle to open. I have driven both throttles on the same LS6 and can find no difference in engine smoothness which would indicate a distribution issue.
myron c
#64
We have never tested the UMI tb on a ls7. The ls7 is still a new engine to us, we have not tested many things yet, but we are trying! The pm you sent was interesting to look at, very nice looking part. It looks like the tb still has a valve that opens in on top? It would be interesting to test one, how fast can you get one to me?
Kurt
Kurt
Originally Posted by UMIRacing
I still haven't had my question answered if you have tested with our throttle body on this subject? We have a few LS7's running around with our throttle body and haven't heard any complaints.
This is our throttle body.
http://www.umiracing.com/news/Umithrottlebody.html
#65
The ls7 intake has the #2 intake port at 12 o'clock position, it seems that they shortened the runners for some added high rpm power. This puts the port opening about 1.3 inches from the closed throttle blade. When it tips in on top it gets closer to ramming the air down cyl #2. On a ls6 style intake the port opening for #2 is to the side of the tb and would not suffer from the same problem.
I have only ran a cable drive on the dyno with it inverted to keep the problem from happening. The only ls7 we have had in a car was stock with the tb that opens in at the bottom. The UMI info on ls7's running well with there tb is promising.
Kurt
Kurt
Originally Posted by TPiS
All of the ls candy cane intakes have #2 entry in the 2 oclock position.
myron c
myron c
#66
I guess the next question then,if the UMI unit works,is if the base where it mounts to the throttlebody is thicker? The throttle blade opens the same way as a NW or TPIS so what are the differences that would make it work versues the other respected units out there. I have a TPIS mounted to a LS7 intake right now. It's only a mock up per say, because I have yet to use it. But the clearances all seem to be good to go. The only problem here would be the A/F ratios and the stumble at part throttle like everyone is talking about. I would be interested to send my throttlebody to test it on a LS7 if there is someone out there with a LS7 thats interested in doing so Traver
#67
I think the NW TB upside down withspacer is the cheaper way to go and if the only difference between the NW TB and the UMI is the cable then I would go NW and save $200.
#68
Kurt
Kurt
PM me with a address and contact info. Better yet, email it to me.
mark@umiracing.com
Thanks,
Mark
#74
Originally Posted by slt200mph
A ton too much hassle to do for no reason.
#75
Part throttle matters. Unless you do some kind of racing, the engine spends like 97% of it's time at part throttle. You want everything to be balanced. You want maximum power all time given any condition.
#76
Closed ex-Sponsor Account
Originally Posted by Ferocity02
Right. I wasnt sure how much work it was. Perhaps some simple wiring would take care of it, but then you need a Vette gas pedal and sensor to control it and the PCM has to be calibrated for it and what not. Perhaps there is a kit.
#77
6600 rpm clutch dump of death Administrator
They are very similar intakes. I hope that answers your Question.
I have had stock LS6,LS2 intake on my 04CTS V, as well as our TPIS Oval and 90MM. I like the TPIS oval on the modified LS6 intake the best. Sharp throttle response, very smooth part throttle and really no difference at full throttle. This car has our TPIS headers and programming
myron c
myron c
We ran one of your oval TB ls6's at one point before going to a FAST. I would think a modified ls6 would be good for a whole bunch of folks since the ls2 intake is down on power compared to the LS6.
Anyway, the info I have came from Gm in their testing. I'm sure as soon as the motors get out there, we'll here if other folks can replicate the same issue.
#78
I was informed that Nick Williams was working on a cable operated throttlebody to fit right on the LS7 intake with no issues.(including airflow) Does anyone out there know if this is true or not? Still trying to decide if I should sell my TPIS 90 mm that I have now and hope by spring time that someone comes up with a new design without any issues! Traver
#79
Our 90MM will bolt on a LS7 intake. You seem to imply that you are having trouble with our 90MM. If you are give us a call and we will resolve any problem at no cost to you. Ask for me, if not here leave a number I'll call you.
Myron Cottrell.pres
952 448 6021
#80
Just thought I should put a link to this here.
https://ls1tech.com/forums/showthrea...3&page=2&pp=20
