90mm Cable TB on an LS7 Manifold... Anyone Accomplished This?
#141
I'm going to update this cable bracket thing if your running a ls7 or ls2 intake. I made a whole bunch of brackets for the cable operated throttlebody simply because there is just nobody out there that makes them. It's a pretty nice piece and you will be able to run the factory throttle cable and cruise cable if needed. Also comes with two longer bolts for the mounting holes. If anyone is interested feel free to PM me. Pictures soon! Traver
#142
#145
Sorry GMW-CSL but none of these individuals mentioned carry or make the bracket we speak of. Trust me, I've spoke to each one and the call for the quanity needed to make a profit didn't justify I guess?! I've made a few and if anyone is interested shoot me a PM. Traver
#146
Oh and Builder...........this should still work with your application.It bolts to the front 2 bolts that attaches the intake to the heads.You could more than likely switch around the corners of the intake where it will fasten.Traver
#147
bracket
I haven't read this whole post, but we make a throttle cable bracket for the LS7 manifold. It will utilize the stock bracket and relocates it to clear the LS7 map sensor and also moves the throttle body farther from the manifold. It utilizes orings for sealing too. I will try to put up some pics tomorrow at the shop. We also make the fuel rails for the LS7 manifold that utilize the stock injectors. It is easier than modifying the stockers, I would be afraid of a leak after welding fittings on the stock rails. Our rails are aluminum with -8 fittings at each end and mount to the stock LS7 location. call or email for pricing. cary@etheads.com 248-668-9390
#148
#149
Cary......you say that you use the stock LS7 bracket but I don't know of any LS7 intake that has a bracket, they are all flybywire that I know of? Maybe I'm misunderstanding your post.I'd be interested to see your bracket also.I was searching this bracket issue and asking every sponsor on here and nobody had one or was even interested in making one so I just fabbed my own.Traver
#150
bracket
Traver,
I used the stock throttle cable bracket from a LS1 and built a spacer and mount for that. I used a Nick Williams TB. Without spacing it away from the manifold, the lever will hit the manifold.
