Cammed LS7 results
Old Dec 29, 2005 | 07:35 PM
gollum's Avatar
Default Cammed LS7 results
From HR magazine.
Old Dec 29, 2005 | 07:37 PM
gollum's Avatar
Default Cammed LS7 results!
From HR Magazine.
Old Dec 29, 2005 | 07:46 PM
Adrenaline_Z's Avatar
Seems like they matched up some exhaust parts as well.
600 HP (at the wheels?) all the way up to 6800 RPM - gawd daym.
Old Dec 29, 2005 | 08:05 PM
gollum's Avatar
Look at Stage 3's exhaust duration. 335 advertised, 276 @.050
Can anyone figure what Stage 3's Lobe Seperation Angle and Installed Lobe Centerline is?
Old Dec 29, 2005 | 08:16 PM
FAST FREDDY's Avatar
these results are based on a engine dyno. this is not rwhp
Old Dec 29, 2005 | 08:28 PM
Still great numbers for the 427.
Torque holds well in the upper range. That's a nice 2500 RPM band of power.
Shift that baby just a touch over 7000 and watch the 11's ease by.
Old Dec 29, 2005 | 08:31 PM
MadBill's Avatar
I get 107.75 LCA, installed 2.75 R.
Old Dec 29, 2005 | 10:27 PM
1CAMWNDR's Avatar
Why did they use such a rediculous split on the Stage 3, and why did they choke it with a 1 3/4 header with a 2.5" collector ?
Put a 238°/248° .610"/.620" 112° LSA + 2° (110° IC) cam in there and a 1 7/8 header with a 3.5" collector!
Old Dec 29, 2005 | 10:42 PM
Beast96Z's Avatar
That's gotta be a misprint on the stage 3 cam.
Old Dec 29, 2005 | 10:45 PM
DramaFoYoMama's Avatar
But isn't 276* normal? I noticed that earlier.
Old Dec 30, 2005 | 12:18 AM
Ferocity02's Avatar
They used a 233/276 cam? Very interesting.
Old Dec 30, 2005 | 05:17 AM
gollum's Avatar
Those two new HOT CAMS from GM, stage 2 and stage3 are soon to be released for the LS7.
Old Dec 30, 2005 | 07:30 AM
WS6FirebirdTA00's Avatar
this was engine dyno? stock cam with headers a little over 500 seems kinda low seeing it does that bone stock, but then again that much rwhp seems kinda high....
Old Dec 30, 2005 | 09:56 AM
Big-DEN's Avatar
540rwhp == 613HP engine, LGM is already getting this with a "small" camshaft. The TQ curve looks like an overlay of the stock cam, so I imagine the LGM cam was not that much bigger in duration but a more agressive lobe.
233/276@.05" sounds pretty bogus to me.
Old Dec 30, 2005 | 10:11 AM
CAT3's Avatar
Restricted User
I agree, why when "testing cams" would you swap headers as well? Should have left the test standard. Nice power though.
Old Dec 30, 2005 | 10:59 PM
Greg Fell's Avatar
My guess is the split is not bogus. Look at the stock LS7 cam, 19* of split. The LS7 heads dont have good exhaust ports. I wonder what this would idle like...these hotcams are all like 108* lsa or so...yikes!
Old Dec 31, 2005 | 10:11 AM
Bink's Avatar
The valve events are wrong on the HR pic.
Example - Stage III @ .050 the Intake opening should be BTDC - Not ATDC. Exhaust closing should be ATDC - Not BTDC.
Also, I believe GM likes asymmetrical lobes so it's hard to pinpoint centerlines.
FWIW.
Old Jan 1, 2006 | 02:35 PM
slimcracka's Avatar
sorry to be off topic but what is the size of the factory ls7 cam??
Old Jan 1, 2006 | 03:14 PM
there are threads floating around with it, i think 211/230
Old Jan 1, 2006 | 04:00 PM
Bryan @ Speed Inc.'s Avatar
yea the first cam spec'd was the stocker
