LS7 regulator in tank or on rail?
Old Jan 3, 2006 | 10:50 PM
Spenser309's Avatar
Default LS7 regulator in tank or on rail?
just thinking that could be a good upgrade if so?
Old Jan 4, 2006 | 05:49 PM
John B's Avatar
Moderator
In the tank. No provision for on the rail!
Old Jan 5, 2006 | 12:45 AM
Spenser309's Avatar
thanks for clearing that up
Old Jan 5, 2006 | 12:53 PM
gun5l1ng3r's Avatar
Which regulator are you guys talking about? Fuel Pressure?
Old Jan 5, 2006 | 04:42 PM
Ferocity02's Avatar
Yes
Old Jan 5, 2006 | 05:59 PM
gun5l1ng3r's Avatar
Just making sure
Old Jan 5, 2006 | 07:27 PM
pcf_mark's Avatar
In the tank - meaning it is part of the fuel pump module? Does this mean it is part of the sender/pump/regulator assembly? Anyone have any idea on retro fitting that to an early car? I was planning using aeromotive pump and regulator set to 43 - 45 lbs or the factory setting with a stainless tank.
Anyone worked this out yet?
Old Jan 5, 2006 | 08:22 PM
John B's Avatar
Moderator
Yes
Exactly!
Too much work. Just use a high pressure fuel pump and an external regulator.
I have a Walbro 340 pump in my tank with an Aeromotive 13109 regulator in the engine bay.
