Is my TRak cam big enough for my 402?
I bought a TR Trak cam to put in my 402. 232/236 .649/.598 111ls I usally see people with more duration, I am not worried about the lift I'm sure its enough. Is this cam going to produce the power I want. Keep in mind I want this car to be driveable everday if I choose. Thanks!
Why is it that that most people think the power comes from a bigger and bigger camshaft? You should ask yourself with that camshaft....do you have enough cylinder head? That camshaft will make more than enough power and more tq than a larger camshaft. Its the runners where you will kill it.
Rick
Rick
find out what your heads flow at say 600 lift and then at 625 650 whereever. then who ever flowin your heads can tell you how big you want too big wont do ne more than a slightly smaller cam and might hurt ya but probably not by much. on the lsa part a 113 gonna make power in a lower rpm range and a 111 or 112 will make power in alittle higher range
Rick
Rick
I agree .If you are looking for a everyday driver with good lowend. you don't need such a big cam unless you are planing to make this a 1/4 mile car.
I know you guys are going to shoot this down but for the time I have to run a stock LS1 head. This motor was not planned so I do not have the funds for the heads I want (etp 225). Had some form of oiling problem, spun 4 rods and 2 mains. I know the car is going to be choked off bad but one step at a time, not made of money right now. Shane at Thunder told about the cam, he knows my set up very well, he said it should make decent numbers still, but numbers will start falling early because of the heads, oh and he said I could get away with stock injectors untill I put heads. Do you think thats correct? One more thing any ideas about how much hp and tq it should make with this set up? Thanks!!!!!!
I ran my old heads for my 402 for a little while and it was fine. Do what you need to do to get your car up and running. Your car is not going to do you ne good just sitting there. You will be around 435-450 rwhp will stock ls1 heads.
Good luck
Good luck
That cam will work great with a 400+ inch motor, especially with that aggressive LSK lobe on the intake. It will basically be like a 224 cam in a 346 which as we know makes very good power and has supreme driving manners. The power you make now is going to be limited by running stock cylinder heads, but your added cubes are going to make it a blast on the street. I say Shane gave you some very sound advice.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
well with that trak cam a buddy of mine from here in laredo....is running a 2002 ceta with a stock 346 with that trak cam and a spec 3 clutch...bmr torque arm with bmr adjustable panhard bar and lower control arms.....hooker lt's with a 3inch y with a bullet before the axle and an asp underdrive pulley...other than that he is running stock heads,intake,injectors,shortblock,....and he managed to run a 11.80 with that Trak cam on all motor and a 10.80 with a 150 dry shot a week ago ,he's already orderd the afr 205's and athe fast 90 intake with the nick williams 90mm throttle body....man he should be running damn good numbers with the heads and intake swap,and plus he ran those numbers untuned...i think he is planning to go to HPE to get it tuned once he swaps the heads and intake..
Trak cam gets two thumbs way up from us laredo,tx ls1 guys!!!
With the larger cubes will effect my idle. I had a 224 cam in my 346 and it sounded good but it did not hit hard enough at idle. I know the TRak cam is larger, but I was worried that extra cubes would tame the idle of that cam. I want the motor to hit harder at idle than my 224 346 cube did.
If you want more lope, lower the idle speed. If 900 rpm is too smooth, lower it to 800, it's as simple as that. A 224 cam in a 346 sounds mean as **** with a 600 rpm idle, LOL.
__________________
Rick
