Warhawk Block?
Old Feb 14, 2006 | 07:25 AM
Katech_Jason's Avatar
LS1TECH Sponsor
Originally Posted by chuntington101
Katech, how much do you think the creat engine will run at roughly?
and what sizes are you looking to sell?
also will these be intake to pan engines or just long blocks?
thanks Chris.
The first size available will probably be the 454, but we can build any combination requested.
It's going to depend on options, but they'll get over $20k easily. They will be complete crate engines.
Old Feb 14, 2006 | 07:41 AM
Carbed4thGen's Avatar
What's the biggest you can go with this combination?
Old Feb 14, 2006 | 07:42 AM
LS1TECH Sponsor
Originally Posted by Carbed4thGen
What's the biggest you cna go with this combination?
454 ci
Old Feb 14, 2006 | 07:45 AM
454 ci
That's it? I figured you'd be able to go bigger with the tall deck and all. Oh well I guess that will just have to be enough
Old Feb 14, 2006 | 07:49 AM
LS1TECH Sponsor
It's a 4.125" bore with .100" sleeves and .300" of alluminum behind that. It can accomodate a 4.250" stroke.
Old Feb 14, 2006 | 08:26 AM
N20LS1's Avatar
The Heads And Block Are Amazingly Affordable.
slt200mph's Avatar
to the top with that
Old Feb 14, 2006 | 08:37 AM
Now could you still take a little bit outta the sleeve to get something around a 460? and is the block able to be "clearanced"? Like could you go with a bigger stroke then just clearance the bottom of the cylinder a bit to accomodate the rod and maybe just fill like an inch of the block with block fill?
Old Feb 14, 2006 | 08:56 AM
LS1TECH Sponsor
That question would best be answered by World products. We like to keep sleeves .100" min.
Old Feb 14, 2006 | 09:48 AM
Ok understandable. Just tryin to get some big cubes
Old Feb 14, 2006 | 09:49 AM
LS1TECH Sponsor
A 454 small block isn't enough!?
Old Feb 14, 2006 | 10:01 AM
  #32
It's never enough! LOL
Old Feb 14, 2006 | 10:22 AM
  #33
LS1TECH Sponsor
Somehow I knew you were going to say that.
Old Feb 14, 2006 | 12:44 PM
  #34
chuntington101's Avatar
so will it be carb'ed or full EFI???
and how much do you prodict you will make from it??? goda be in the 700bhp (crank) hasn't it?????
Chris.
Old Feb 14, 2006 | 01:12 PM
  #35
LS1TECH Sponsor
Chris.
EFI
700+ isn't out of the question
Old Feb 14, 2006 | 07:36 PM
  #36
Warhawk 1's Avatar
LS1TECH Sponsor
Talking
Carbed4thgen,
We tend to agree with Katech, we like to keep our sleeves at .100" thick, however, the General goes smaller (.07"). We don't recommend it though. We are investigating a 4.5" inch swing crank. If that would prove successful, we would generate 481 cubes. I realize that is probably not big enough still...
B
Old Feb 14, 2006 | 09:10 PM
  #37
Dune-LS1's Avatar
Originally Posted by Warhawk 1
Carbed4thgen,
B
Will the tall deck blocks be available the same time as the standard deck blocks?...
Old Feb 15, 2006 | 12:04 AM
  #38
MountainMotor's Avatar
454ci is nice but 481ci !
Old Feb 15, 2006 | 12:12 AM
  #39
Carbed4thgen,
B
Ok if you guys need any help with trying to fit anything I would love to try this all out. If you'd like to know how far this combo can go once again I'd be there if anything was needed
Old Feb 15, 2006 | 01:20 AM
  #40
98cobrakillata's Avatar
I need a lottery ticket!
