Warhawk Block?
Old Feb 10, 2006 | 06:35 PM
Ls1LikeNoOther's Avatar
Default Warhawk Block?
Im sure a lot of you saw the new block from World for the LS series motor but has anyone seen it in person yet?What are everyones opinions on that and the heads?
Old Feb 10, 2006 | 07:21 PM
Ferocity02's Avatar
I'm liking the heads myself. They should flow killer number for a great price. The block and heads together should make for an unbeatable combination. With the 6 bolts/cylinder, more boost or nitrous is possible. I am planning on using the heads on my motor.
Old Feb 10, 2006 | 07:30 PM
MerlinPro's Avatar
Collections Removal
LS1Like,
Our block is called the "Warhawk". Warren and Kurt Johnson, the Katech folks and many others really approved what they saw at SEMA.
Ferocity02 summed things up very nicely, for which we thank him!
A free brochure is available by calling our World sales dept. 631-981-1918, ext 107.
Thanks for your interest.
Regards,
Old Feb 10, 2006 | 07:38 PM
Phoenix 5.7's Avatar
I have a feeling we are goin to see some rediculus setups involving that block as the basis. its gettin interesting...
Old Feb 10, 2006 | 08:41 PM
Ferocity02's Avatar
Originally Posted by MerlinPro
LS1Like,
Regards,
I am just VERY interested in the heads. I would have gone with your block also except I already had one sleeved and ready to go. I am curious to see how well your heads will work on an LS6 block. Looking for BIG hp number as well. Do you need a testing vehicle for the first set of heads?!?!
Old Feb 11, 2006 | 12:25 AM
I also plan on using the heads and block,Some sort of ridiculous cubic inch all motor combo,got a solid roller grind already in the works,just need to figure out which valvetrain I need to use which is why I wanted to know more info on it,Also which intakes will work on it,bc I would like to switch to DFI or the Carb LS1 Conversion but i was unsure as to what would work..
Old Feb 12, 2006 | 02:18 PM
hc_performance's Avatar
What is the price of these heads and block going to be????
Old Feb 12, 2006 | 03:16 PM
Ferocity02's Avatar
I've heard about $799 each, bare. Then around $1150 each, assembled. The assembled price would be killer assuming they use titanium intake valves and sodium exhaust valves, along with some heavy duty springs and Ti retainers. I don't know how much the block is going to be, maybe around $3800?
Old Feb 12, 2006 | 04:15 PM
Katech_Jason's Avatar
LS1TECH Sponsor
I'm not at work, but if I can remember it's $3999.99 for the standard deck and $4199.99 for the tall deck.
Old Feb 13, 2006 | 01:19 AM
Carbed4thGen's Avatar
If one was to go with this block and heads with a carbed intake wat PCM would be needed to run it? a stand alone estup or a ls1/ls2 setup or would you have to go to a ls7 setup?
Old Feb 13, 2006 | 11:56 AM
LS1TECH Sponsor
You don't need a PCM. You can run the coils with an MSD system.
Old Feb 13, 2006 | 12:11 PM
Spellbound's Avatar
Will the tall deck fit under the cowl of an F-bod or vette?
Old Feb 13, 2006 | 12:34 PM
LS1TECH Sponsor
Want to be the first to test?
Old Feb 13, 2006 | 02:04 PM
LS1TECH Sponsor
I've got a lot of price inquiries lately and since I just got the newest pricing sheet today I figured I would post it.
CYLINDER HEADS
64cc Bare Casting $799.99 ea
64cc Mech/Hyd Roller 1.437" Dual spring Assem. $1029.99 ea
64cc Solid Roller 1.550" Dueal Spring Assem. $1134.99 ea
72cc Bare Casting $799.99 ea
72cc Mech/Hyd Roller 1.437" Dual spring Assem. $1029.99 ea
72cc Solid Roller 1.550" Dueal Spring Assem. $1134.99 ea
BLOCKS AND COMPONENTS
9.240"x3.990", billet cross bolted main caps $3999.99
9.240"x4.115", billet cross bolted main caps $3999.99
9.800"x4.115", billet cross bolted main caps $4199.99
Camshaft retainer plate (req.) $79.99
Rear seal cover (req.) $109.99
Valley cover plate (rec.) $109.99
Cylinder head stud kit, 9.240" block, 4 per cyl (req.) $279.99
Cylinder head studs, 9.240" block, 2 additional studs per cyl (opt.) $159.99
Cylinder head stud kit, 9.800" block, 4 per cyl (req.) $279.99
Cylinder head studs, 9.800" block, 2 additional studs per cyl (opt.) $159.99
We will start taking parts orders and Katech-built crate engine orders as soon as parts are available.
Old Feb 13, 2006 | 02:25 PM
Spellbound's Avatar
I would love too
Old Feb 13, 2006 | 06:18 PM
My cars already gutted and caged and ready
I mean if u wanted haha
Old Feb 13, 2006 | 08:52 PM
LS1TECH Sponsor
I would love too
Either of you can call me up and place your 50% deposit and we'll get started.
What, you thought you were getting it for free?
Old Feb 13, 2006 | 11:01 PM
adams2003's Avatar
CYLINDER HEADS
We will start taking parts orders and Katech-built <a style='text-decoration: none; border-bottom: 3px double;' href="http://www.qklinkserver.com/lm/rtl3.asp?si=92&k=crate%20engine&st=1" onmouseover="window.status='Search for: crate engine'; self.ql_skeyphrase='crate%20engine'; if(window.event) self.ql_sevent=window.event.srcElement; self.ql_timeout = setTimeout('ql_doMouseOver(1)', 1000); self.ql_isOverLink=true; return true;" onclick="if(self.ql_timeout) clearTimeout(self.ql_timeout); self.ql_isOverTip = false; ql_closeiframe(); self.ql_skeyphrase='crate%20engine'; window.status='Search for: crate engine';return true;" onmouseout="window.status=''; if(self.ql_timeout) clearTimeout(self.ql_timeout); self.ql_isOverTip = false; setTimeout('ql_closeiframe()', 1500); ">crate engine</a> orders as soon as parts are available.
Would the bottom two blocks be 427's with a 4" stroke? Also, are these resleeved ls2 blocks?
Old Feb 14, 2006 | 12:47 AM
jrp's Avatar
jrp
SN95 Director
yes. and no, these are not OEM blocks, they are a completely different casting.
Old Feb 14, 2006 | 07:15 AM
chuntington101's Avatar
Katech, how much do you think the creat engine will run at roughly?
and what sizes are you looking to sell?
also will these be intake to pan engines or just long blocks?
thanks Chris.
