I got my L-92 heads
Old Feb 15, 2006 | 06:24 AM
See5's Avatar
From Chicago Autoshow>
Has offset exhaust rocker.
Old Feb 15, 2006 | 09:08 AM
Eddiep's Avatar
Do you know if these use the standard length '04+ LSx head bolts/studs?
Old Feb 15, 2006 | 09:32 AM
oange ss's Avatar
chamber looks like the old fast burn heads
Old Feb 15, 2006 | 11:57 AM
1997 vet's Avatar
What cc is the combustion chamber.
Old Feb 15, 2006 | 06:01 PM
7.0PewterHawk's Avatar
71cc I believe
Old Feb 15, 2006 | 10:26 PM
phantom meneSS's Avatar
Yes. Even length bolts.
Old Feb 16, 2006 | 12:29 AM
67camaro's Avatar
does anybody know the size of the intake ports?
Old Feb 16, 2006 | 04:03 PM
ifryrice's Avatar
A FAST intake manifold wont work on these?
Old Feb 16, 2006 | 04:04 PM
adams2003's Avatar
It should be able to.
Old Feb 16, 2006 | 04:17 PM
Haans249's Avatar
checked prices on gmpartsdirect.....160 a piece bare....wow....THATS INSANELY CHEAP!!!!!
Old Feb 16, 2006 | 07:22 PM
Nate_Taufer's Avatar
No it will not. With a lot of modification it could though.
Nate
Old Feb 16, 2006 | 08:36 PM
  #32
Steve Bryant's Avatar
LS1 Tech Veteran
Has anyone seen anything about the flow rates on these heads as-cast and/or ported at various lifts? If so, where can I find this information?
Thanks,
Steve
Old Feb 16, 2006 | 11:38 PM
  #33
Thanks,
Steve
Read post 19.
Nate
Old Feb 17, 2006 | 03:48 PM
  #34
xfactor_pitbulls's Avatar
Nate
Nope, the runners are too wide and you would end up outside the o-ring. GM or sheetmetal.
Brandon
Old Feb 17, 2006 | 03:51 PM
  #35
Originally Posted by J-Rod
The runer is actually taller, so you'd have to fill the floor probably.
Yuck, that is a scary proposition with even a stock shortblock, much less a nice forged setup. Too many epoxies fail.
Brandon
Old Feb 19, 2006 | 01:22 AM
  #36
BLASTER's Avatar
So will the GM truck intake definately bolt to these? because so would my Magnacharger?
Article says they will work on LS2 so I guess we can assume any 6.0L derivitive block.
Old Feb 19, 2006 | 03:01 AM
  #37
Any 4.0" bore block will work
Old Feb 20, 2006 | 02:02 PM
  #38
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Guys I have several sets without seats & guides for $250 a pair!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Feb 20, 2006 | 02:08 PM
  #39
See5's Avatar
That is fabulous if we can be assured of an intake that fits under a Ybody hood. Seriously fabulous.
Old Feb 22, 2006 | 12:37 PM
  #40
LS1 Tech Veteran
Actually, the L92 and LS7 heads should both work on any LS series block with a minimum bore of 4.00" However, the interface between the intake manifold and the intake runners is different. The LS2/LQ4/LQ9/MagnaCharger RADIX/All Current Aftermarket Manifolds are set up for a cathedral roofed style interface. The L92 and LS7 inlet ports are rectangular and are different from each other (mainly in height as far as I can tell). Unless you can get and use either an L92 or an LS7 factory intake manifold, the L92/LS7 heads won't work. I'd about guarantee though that MagnaCharger and everyone in the aftermarket intake manifold business for Gen III/IV is developing manifolds now. I'm sure too, that the factory LS7 and L92 intakes probably flow well in their current state. However, if you want to use an LS7 manifold on an L92 head, there's going to be a pretty big mismatch. If the L92 intake runner were ported to be properly matched to an LS7, that would probably work fine.
Steve
Steve
