LS2 Timing Chain Dampner
Old Mar 15, 2006 | 10:42 AM
Greg Fell's Avatar
My block is an 05 5.3 alum block, and it requires the larger (more expensive) dampner.
Old Apr 4, 2006 | 08:46 PM
mr2guru's Avatar
I've got an '04 GTO block here and it's drilled but it's for the old damper
It also has the older 'long/short' head bolt holes.
crap
Old Apr 28, 2006 | 03:59 PM
kpforce1's Avatar
Does a 99 LS1 have a damper?
Old Apr 28, 2006 | 07:27 PM
DrkPhx's Avatar
Not installed from the factory. It should have the bosses which you may have to drill and tap for the dampner. My 98 block was drilled and tapped from the factory. I don't believe the 99's are drilled. You will have to check.
Old Jun 17, 2010 | 04:34 PM
PlatnumStatuz's Avatar
Mine did
Old Jun 23, 2010 | 10:24 AM
slap(A)hoe's Avatar
im putting a 04 model ls motor in my 98 z i was planning on just using the balancer from my stock motor with a ls2 timing chain set will this be ok ???
