ls2 long block in my 2000 SS
questions....
WILL MY LS6 INTAKE FIT?
WILL MY ACC. ALL FIT?
WHAT DO I NEED TO DO ABOUT MY RELUCTOR WHEEL?
ARP ROD BOLTS AND HEAD STUDS ENOUGH FOR THE 150 SHOT WITH A FRESH MILLED HEAD AND COMETIC GASKETS?
Anything else I need to consider if I'm going with the LS2?
I don't really want the weight of the LQ9 unless i'm going FI. Any help will be appreciated. I get my check soon so I need to make a decision.
Yeah a 150 shot will be fine with a good tune and Lingenfelter also sells a box if the LS2has the 58X reluctor.
katech knock sensor extension harness and cam angle sensor harness and bolt it up. The motor is out of an 05 C6.
This is all I need? Besides some bigger injecters and a walbro fuel pump? My 2000 LS1 came with 26lbers. I'm thinking some 36lbers and a walbro witha hard wire kit??
Now for the million$$ question.
WHAT CAM???
228R, Torquer V2, or oem LS6 cam??
I would like to just buy a used LS6 cam and save the valve spring money for my HSW wet kit. If not I will be doing the TSP single spring package with the PAC 1518's and a mild cam. TV2,228R, etc.
