The Scoop on LS7X Warhawk
Old Mar 6, 2006 | 04:42 PM
1 Fine 69's Avatar
Default The Scoop on LS7X Warhawk
Just got the brochure from world. 454 block, 12 and 15 degree heads all look sick. If you have any questions ask away!
Old Mar 6, 2006 | 05:11 PM
xfactor_pitbulls's Avatar
Uh.......can you scan the ******?
Brandon
Old Mar 6, 2006 | 05:33 PM
1 Fine 69's Avatar
Nah i wish man i dont have a scanner
Old Mar 6, 2006 | 05:35 PM
MerlinPro's Avatar
Collections Removal
Brandon,
We would be happy to mail or fax you the...er MATERIAL, free. Call 631-737-0372, ext 107 and ask.
Regards,
Old Mar 6, 2006 | 05:37 PM
1 Fine 69's Avatar
givin you some business merlin....itd be nce if u cut me a rpice on all aluminum 427 haha
Old Mar 6, 2006 | 06:55 PM
Katech_Jason's Avatar
LS1TECH Sponsor
Brandon
It has been posted on LS1tech before but I just cant find it.
Old Mar 6, 2006 | 07:01 PM
jrp's Avatar
jrp
SN95 Director
been posted a few times actually. i thought this was gonna be new news that we didnt already know. i've got the press material from PRI scanned and posted back when, Tony also posted it. all the info is in the new hotrod and some other primedia mags.
Old Mar 6, 2006 | 07:16 PM
1 Fine 69's Avatar
Thought i would offer the material from the actual brochure from world...just trying to help
Old Mar 6, 2006 | 07:36 PM
FACE's Avatar
Originally Posted by MerlinPro
Brandon,
Regards,
I live a mile from the shop, let me know if you need a C5 donor car.
Old Mar 7, 2006 | 06:30 AM
Wet 1's Avatar
That's what he's talking about... it's been posted here for months.
Old Mar 7, 2006 | 06:36 AM
Cool_Hand_Luke's Avatar
It's got pretty good info.
Make me feel like a kid looking at the old Sears Christmas wishbook. Here are the basics so you don't have to search.
CYLINDER HEADS
64cc Bare Casting $799.99 ea
64cc Mech/Hyd Roller 1.437" Dual spring Assem. $1029.99 ea
64cc Solid Roller 1.550" Dueal Spring Assem. $1134.99 ea
72cc Bare Casting $799.99 ea
72cc Mech/Hyd Roller 1.437" Dual spring Assem. $1029.99 ea
72cc Solid Roller 1.550" Dueal Spring Assem. $1134.99 ea
BLOCKS AND COMPONENTS
9.240"x3.990", billet cross bolted main caps $3999.99
9.240"x4.115", billet cross bolted main caps $3999.99
9.800"x4.115", billet cross bolted main caps $4199.99
Camshaft retainer plate (req.) $79.99
Rear seal cover (req.) $109.99
Valley cover plate (rec.) $109.99
Cylinder head stud kit, 9.240" block, 4 per cyl (req.) $279.99
Cylinder head studs, 9.240" block, 2 additional studs per cyl (opt.) $159.99
Cylinder head stud kit, 9.800" block, 4 per cyl (req.) $279.99
Cylinder head studs, 9.800" block, 2 additional studs per cyl (opt.) $159.99
Old Mar 7, 2006 | 06:39 AM
Wet 1's Avatar
Yeah, good luck with that!!!
Old Mar 7, 2006 | 07:07 AM
Reckless's Avatar
Super Moderator
When will they be available? We will likely be doing something with one of these blocks, so I'd like to know when they will be available to shops such as ours?
Thanks!
Old Mar 7, 2006 | 08:47 AM
1 Fine 69's Avatar
that will probably depend on world
Old Mar 7, 2006 | 03:03 PM
Ferocity02's Avatar
The heads are due out in April/May I believe. Do a search in this section, I believe they mentioned the release dates a few times.
Old Mar 7, 2006 | 05:29 PM
MerlinPro's Avatar
Collections Removal
Todd Brandon,
I will have our Sales Manager Frank DiFranco call you tomorrow to discuss timing and your needs. Thanks for your interest.
Regards,
