LS7 lifters??
Old Apr 10, 2006 | 08:03 PM
StreetnStrip's Avatar
Closed ex-Sponsor Account
Default LS7 lifters??
i thought i read it before that the LS7 lifters were good for High reving motors is this true and what part number are they?
Old Apr 10, 2006 | 08:34 PM
MM98's Avatar
Part#17122490... This lifter is used on all the LSx based car & truck motors including the LS2 & LS7.
Mike
Old Apr 10, 2006 | 08:36 PM
Quik's Avatar
so youre saying its the stock production lifter thats been around since 97???^^^
Old Apr 10, 2006 | 08:52 PM
MM98's Avatar
Correct.
Old Apr 10, 2006 | 08:55 PM
Originally Posted by MM98
Correct.
i thought there was a psot on here saying the LS7 lifter could turn higher RPMs then the stock ls1?
Old Apr 10, 2006 | 10:39 PM
Unaffliated Racing's Avatar
Try more like 1987...
Old Apr 10, 2006 | 10:42 PM
Quik's Avatar
ouch, even after all these years you think they would learn. doesnt make sense why these lifters just fail for no appreant reason
Old Apr 10, 2006 | 10:45 PM
There are ALWAYS reasons. People would rather just blame the lifter and get on with their lives....
Old Apr 10, 2006 | 10:51 PM
Quik's Avatar
why do you think they fail so much then
Old Apr 10, 2006 | 10:59 PM
That's the thing...I don't think they fail much. A stock lifter does a great job of what it is supposed to do. Millions of vehicles out there with that very same lifter that have no problems at all. I know...the next thing that will be said is that these are modified vehicles we are talking about. Ok....go buy a lifter designed for that application. The thing is that there are too many variables that may cause lifter failure. Just like the failure of any internal engine part.
Old Apr 11, 2006 | 02:49 AM
i understand what ur saying but if the LS7 lifter is the same as a lifter in a 2002 LS1 motor then how come the LS1 motor fails when u put a cam that is smaller then .600 lift? I mean if I remember correctly aint the new Ls7 cam like 595 598 lift? If so then those lifters should be able to take abuse a ls7 can take.
Old Apr 11, 2006 | 07:15 AM
I don't see that happening.... I worked for Comp for two years and it was a very rare deal to see a hydraulic roller lifter fail for no apparent reason. That is in all motors that use this lifter...not just the LS-1. Another thing..you are looking at lift and lift alone....the ramp rates of an aftermarket cam are far more aggressive than an LS-7 cam anyday.
Old Apr 11, 2006 | 11:46 AM
so for now on instead of me asking jeeves I should jsut ask u.
Old Apr 11, 2006 | 11:53 AM
be a wise ***...I don't care
Old Apr 11, 2006 | 12:10 PM
JC5's Avatar
JC5
LS7 has 1.8 rockers!
Old Apr 11, 2006 | 12:46 PM
bg-sdpc's Avatar
LS1TECH & Trucks Sponsor
The LS6 and LS7 can rev higher because they have lightweight valves. The LS2 has the same head casting but not the lightweight valves.
Old Apr 11, 2006 | 01:17 PM
Mike Norris's Avatar
I'll throw in my 2 cents on the lifter failure and agree with Unafilliated Racing that most lifter failures are due to their use with some aggressive cams is beyond the design. Yes, the ramp rates are part of the problem, but the seat and open pressures do a number on a stock lifter. We tend to run lighter seat & open pressures based on application then most other shops with no failures and still run to 68-7000 RPM on an XER lobe. Hope this helps.
Mike Norris
Old Apr 11, 2006 | 02:17 PM
Im just joking bud dont take it the wrong way
Old Apr 11, 2006 | 04:19 PM
JZ'sTA's Avatar
I must also agree.
We has had 1 count it 1 car with lifter problems in the past 5 years.
I think the stock lifters do a great job.
I would guess we have had 150+ modded LS1's/LS6's during that time spand and only 1 set has had a problem. This was also a 65,000 mile 2000 LS1 that has had 1000's of races under his built with a 400 cubic inch motor, and a aggressive ramp rate on the cam.
Old Apr 13, 2006 | 03:47 PM
SSblack98's Avatar
It does list the LS7 lifters in the 2006 GM performance catalog and states that they are specially design for high rpm applications...
