Got a couple questions about the LS7
For one the LS7 has sodium filled exhaust valves.... sodium?? like salt? When I was talking to someone who had a WRX STI I remember them saying something in their engine was sodium filled as well. What advantage does this provide?
2. And this is one I should know but how is the dry sump oiling system different than a avg passenger car oiling system and how does it make sure oil is flowing through the engine even under accelerative, braking and cornering forces?
3. the LS7 uses titanium connecting rods. I understand the weight savings titanium would have and how important saving weight is in all reciprocating mass in your engine and drive train but for the most part isnt it better in high stress applications to make the componets that are dealing with the forces of combustion out of a alloy that can expand and contract slightly like iron? Obviously the block is aluminum which is also known for being quite rigid so very rigid materials can be used, but isnt titanium the most rigid alloy you could use? Doesnt this meen that if the rod goes it will more than likely shatter complelty tearing appart everything in that cylinder from the piston to the sleeve to the head?
Sorry for the noob questions
Thanks
The valves are filled with the element sodium, not salt (Sodium Chloride). The primary purpose of a lighter valve is to maintiain control due to less inertia.
The primary purpose of the dry sump system is to have a ready supply of oil to the pressure pump, particularly under high-g cornering. Reduced windage is also a horsepower-saving advantage.
Sodium filled valves allows much greater heat dissipation... That is the primary reason for using them. The weight savings is just an added benefit.
Boosted.
