LS7 emissions, 24X, cable TB?
Old May 6, 2006 | 09:42 AM
GMW-CSL's Avatar
Default LS7 emissions, 24X, cable TB?
Does it seem likely that an otherwise stock LS7 controlled with a 24X reluctor, a properly calibrated LS1 PCM and a 90mm cable throttle body would pass emissions outside of Ca?
Old May 6, 2006 | 10:14 AM
John B's Avatar
Moderator
It would fly through a tailpipe test! Especially with CATs on. My forged 347 with a lumpy 3X CARTEK cam (mid 230's duration) passed with flying colors (with a little tweaking and a few tricks of course!).
Old May 8, 2006 | 11:38 AM
greekss's Avatar
like what ?
Old May 8, 2006 | 01:15 PM
OmniRex's Avatar
I've heard of ppl hooking up an air tank to the exaust...
Old May 8, 2006 | 01:20 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
It's all in the fuel blend.
You've got "regular", "premium", and "pass the emissions test blend".
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old May 8, 2006 | 01:39 PM
bigredexpress99's Avatar
could you elaborate more on the tricks you used to pass........and the emissions test blend of fuel...
Old May 8, 2006 | 03:14 PM
MSURacing's Avatar
Pass the emissions test = Ethanol!!!!
Put some cats on, 15% ethanol, change the oil, new spark plugs and retard the timing about 7 degrees and you'll be looking at a nice certificate!!!
Old May 8, 2006 | 04:20 PM
GMW-CSL's Avatar
You guys are the best when a guy needs alittle extra help. I am subject to emissions but the guy across the street (almost) is in a different Zip Code and he isn't subject to emissions testing. Our laws at work!!!
