Warhawk Update
Old Jun 13, 2006 | 07:43 AM
  #61
MerlinPro's Avatar
Collections Removal
CAT3,
Our Warhawk block does not use OE covers for cam retention, valley cover or rear plate. We had to design our own due to the unique oiling and casting design. We have the covers available and the parts will be priced for the web site and catalog when blocks finally come.
The 9.800" block will require spacers.
We're going to mock-up a 4.500" Callies for 481 cid, when blocks come.
Thanks for asking.
Old Jun 13, 2006 | 12:02 PM
  #62
CAT3's Avatar
Restricted User
Originally Posted by MerlinPro
CAT3,
Thanks for asking.
Good googley moogley, thats some good news. Thanks....
Old Jun 13, 2006 | 12:15 PM
  #63
bmfcamaro's Avatar
thing is goig to be a beast
Old Jun 13, 2006 | 12:49 PM
  #64
ram09's Avatar
Originally Posted by LT1LE
5.000"
WHOA WHOA WHOAAA!! If this is true then a tall deck WARHAWK block with a 4.125 inch bore and a 5.00 inch stroke comes out to 534 CUBIC INCHES!!!!! Now that is hard to take, basically a small block chevy with 534 CI!!! I dont know if I can believe that.
Old Jun 13, 2006 | 01:05 PM
  #65
Ferocity02's Avatar
Will the LS7x heads be able to use standard LS1/6 ARP head bolts and studs when used on an LS1/6 block?
Old Jun 13, 2006 | 01:18 PM
  #66
LT1LE's Avatar
Yes....
Old Jun 13, 2006 | 06:19 PM
  #67
MerlinPro's Avatar
Collections Removal
LT1LE,
Will you share how you know this? Have you done this??
Old Jun 13, 2006 | 07:20 PM
  #68
LT1LE's Avatar
LT1LE,
AN ARP REP I TALK TO SAID THAT HE HAD A FEW CUSTOMERS USING ARP 234-4317 HEAD STUDS ON THEIR BIG BORE LS1'S WITH GM LS7 HEADS.
Old Jun 13, 2006 | 08:52 PM
  #69
Ferocity02's Avatar
My question was in reference to the Wakhawk LS7x heads, not the GM LS7 heads. I suppose I could have made it more clear.
Old Jun 13, 2006 | 09:21 PM
  #70
LT1LE's Avatar
THE GM LS7 HEADS AND WARHAWK LS7X HEADS ARE SUPPOSED TO BE INTERCHANGEABLE WITH EACH OTHER. (OR SO I THOUGHT)
Old Jun 13, 2006 | 09:31 PM
  #71
MrDude_1's Avatar
im sure with the exception of the extra bolts, the bolt PATTERN is the same... however the LENGTH of the studs could be totally diffrent.
plus they could be larger holes ment for 1/2" studs or something... theres no way to know for sure until they actually release the heads.
Old Jun 14, 2006 | 12:19 AM
  #72
CAT3's Avatar
Restricted User
1/2" ARP Studs + More of them per cylinder sounds really nice
Old Jun 14, 2006 | 12:40 AM
  #73
Ferocity02's Avatar
I sure hope they aren't meant for just 1/2" studs. Or else I'll have to have the block drilled and tapped
Old Jun 14, 2006 | 12:44 AM
  #74
smok'nZ's Avatar
MASS seller approved
Originally Posted by badaSS346
I think the only way to make it up to the LSx community is to give me a block and a set of heads for free
+2.....
Old Jun 14, 2006 | 09:02 AM
  #75
DavidNJ's Avatar
Where the Warhawk LS7 heads with the matching 6 bolt holes designed for porting (e.g., with small ports and chamber) or for use as cast?
Old Jun 14, 2006 | 09:18 AM
  #76
MerlinPro's Avatar
Collections Removal
Default To Clarify The Head Stud Question
Ferocity,
LT1 is correct in stating that Warhawk heads will attach to OE blocks using OE dimension studs. If that is the correct ARP number, it's fine.
When using Warhawk heads on the Warhawk Block you must use the ARP kit (custom made to our spec), specific to our block. We offer ARP kits for the 9.24 and 9.8 deck blocks with companion kits for the additional 16 studs for 6-stud per cylinder attachment. For the record, OE studs are 10mm. Warhawk-specific studs are 7/16 at their major diameters.
Old Jun 14, 2006 | 09:24 AM
  #77
MerlinPro's Avatar
Collections Removal
David,
The 12 deg LS7X head is designed for use "as cast", but there is material available for porting. The chambers are 64 and 72CC and the intake runner is 255CC.
Old Jun 14, 2006 | 12:27 PM
  #78
Ferocity02's Avatar
Thanks for the info!
