4.125" stroke in a LS2 block = ____ cu. "
Old May 13, 2006 | 09:54 AM
David Gordon's Avatar
Default 4.125" stroke in a LS2 block = ____ cu. "
I was wandering how many cubic inches I would have putting my crank in a LS2 block?
I currently have a 395" stroker and was wanting to get to at least 520 rwhp.
Thanks
Old May 13, 2006 | 10:01 AM
Katech_Jason's Avatar
LS1TECH Sponsor
Thanks
414
_
Old May 13, 2006 | 10:07 AM
Thanks.
What would be the normal power level I might achieve with this not going full race. I was even thinking of keeping my cam 240/244 610 112. I would like to get the best heads I could get though.
Old May 13, 2006 | 11:39 PM
Judd's Avatar
Would a 4.125 or a 4.100 crank work well as far longevity? Any special conciderations?
Old May 14, 2006 | 07:21 AM
niphilli's Avatar
Volume of a cylinder = PI*R^2*H
Where Pi = 3.14, R=Bore/2, H=Stroke
So for a 4" Bore & a 4.125" stroke
(3.14)*(2^2)*(4.125) = 51.81 cubic inches per cylinder
51.81 * 8cylinders = 414ci.
Old May 14, 2006 | 09:58 AM
Randy WS6's Avatar
Im building a aluminum LS2 418cid. 6.8L , 4.100" crank & 6.125" rods and 4.030" bore.
Old May 14, 2006 | 10:54 AM
camaroextra's Avatar
A goal of mine is to build a 427 out of an LS2 one day
4.060 bore x 4.125 stroke
Old May 14, 2006 | 11:01 AM
Rock_Daddy's Avatar
That is where the L92 block will shine. Its stock bore is 4.060 or 4.065
Old May 14, 2006 | 11:05 AM
What! nice, thats gona be sick!
Old May 14, 2006 | 11:08 AM
Will it be aluminum or iron?
I already have the 4.125 crank and rods.
Old May 14, 2006 | 11:28 AM
Rock_Daddy's Avatar
It's AL just like most of the LS family. There is lots of into in the sticky's of this forum. Everyone is waiting for them to become available.
Old May 14, 2006 | 12:31 PM
gnx7's Avatar
L92 is the '07 Escalade motor and is alum block/heads. The block is not yet available; however should be shortly.
Most people like to stick with 4" cranks, but plenty do run longer ones. A shorter throw typically allows you to rev it higher (safely).
Old May 14, 2006 | 12:47 PM
I have been reving my 4.125" stock bore to 7k for a long time. It made 470 rwtq. 2 years ago and the torque is from idle to 7k.
What would my 4.125 stroke crank make in the 6.2 litre block?
Old May 14, 2006 | 12:57 PM
Rock_Daddy's Avatar
Looks like a hair over 427
