LS7 price
Old Jun 27, 2006 | 08:21 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Originally Posted by jellison
Cheers Guys - can we have a vote on which is the BEST after market 90mm throttle body - (I have heardsome are crap!).
Pity I would not be able to use the Header! Presume it is a sort after item and could sell on? (I have to go forwards with custom made headers for a TVR).
Instead of jumping to the aftermarket you might want to give some thought to using the stock throttle body and GM ECM to run your engine. The GM fly by wire system works great, is very easy to hook up, and the stock throttle body has great driveablilty AND performance!
The other big advantage of staying with the GM setup is the diagnostic capabilities. It's very handy to be able to plug a Tech 2 or any up to date diagnostic tool in to the system and see everything going on. You give all of that up with the aftermarket setups.
We've done over 30 of these systems now and the ones that are up and running are running great! Good power, good street manners, it's a setup that's tough to beat.
Just "food for thought". So many people want to jump to the aftermarket for a controller, and switch over to a throttle cable, when the factory type setup offers so many advantages.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Jun 27, 2006 | 01:20 PM
John B's Avatar
Moderator
Couldn't have said it better myself John! My stock LS7 fly-by-wire TB set-up with your harness & programming is just as sweet as could be...especially since my car is a daily driver!
Old Jun 28, 2006 | 09:34 AM
jellison's Avatar
Anyone got a picture of the engine (7) with the Dry Sump pump attached - straight on from the front woul be good - just want to check that it is likely going to be too wide for the chassis in this area and then have to use a hot ls2/6
Old Jun 28, 2006 | 10:34 AM
SLED28's Avatar
Originally Posted by slt200mph
It depends on your perspective..you can build a hell of a stroker motor for quit a bit less.
I agree, but then again I've never been a crate-engine type guy... Half the fun is modding it and just waiting for those parts to show up!
Old Jun 28, 2006 | 11:01 AM
Bill Reid's Avatar
... trying to keep this dial-up friendly here... take a look at the links to the pics...
The LS7 has an internal dry sump system as shown in previous pics... externally the differences are minimal and/or offset. Although the LS7 crank has a longer snout it has an offset harmonic balancer that will allow the use of C5/C6 Corvette accessory drive componants. No other GM GENIII/IV based vehicle has an accessory drive bracket system that will line up with the factory LS7 harmonic balancer. There are ways of converting the LS7 to wet sump... but they are time consuming and only add expense to the crate motor... not to mention reluctor wheel differences that require planning and/or changes in how you will tune or the equipment that you will use to manage and tune the engine. You would also need to make room in the engine compartment for a 2 gallon oil tank.
If you know for a fact that the LS7 oil pan will not fit in the chassis of the vehicle you are working with then you might be better off scratch building an LS2 (either stock 6 liter or resleeved to larger bore along with a 4" stroker crank to achieve 7+ liters) if you already have an oil pan in mind that you know for a fact will fit.
Bill
http://FileLibrary.MYAASite.Com/Cont...4/16853713.jpg
http://FileLibrary.MYAASite.Com/Cont...4/16853760.jpg
http://FileLibrary.MYAASite.Com/Cont...4/16853787.jpg
http://FileLibrary.MYAASite.Com/Cont...4/16853848.jpg
http://FileLibrary.MYAASite.Com/Cont...4/16853874.jpg
http://FileLibrary.MYAASite.Com/Cont...4/16854226.jpg
http://FileLibrary.MYAASite.Com/Cont...4/16854271.jpg
http://FileLibrary.MYAASite.Com/Cont...4/16854287.jpg
Old Jun 28, 2006 | 11:34 AM
NOSjohn's Avatar
Restricted User
Very nice pics of specific areas of the LS7...thanks for sharing!
Old Jun 28, 2006 | 12:47 PM
Builder's Avatar
Originally Posted by piusk
wheel to wheel did a good honest dyno(rare to see) on ls7 for a customer.
no playing with temps, or barometer, using unknown dyno headers.
tried several throttle bodies incl fast. umi throttle body with spacer showed 8 hp more across band. topped out at stp dyno at 564 hp at 6000, 543 ft-lbs
at 4800.
dyno info was on this site some time ago. found pictures of engine and hose adapter and dyno at www.ihp.com under gtr kit car info.
I was the customer. Yes, www.ihp.com is the location for more information. Drop me a line if you have any questions. There were a number of other mods, as the intake manifold was spun 180 degrees for a reverse installation in a mid-engine chassis.
The ECU and harness is BigStuff3.
