What heads to drop compression on GTO LS2?
Old May 17, 2006 | 06:48 PM
caindo's Avatar
Default What heads to drop compression on GTO LS2?
Putting on a d1sc procharger and looking to drop the compression some. What heads would work the best/easiest. Not looking for any performance increase, just lower CR. would like them to be assembled with comperable springs to suit 550+.
Old May 17, 2006 | 08:27 PM
DrkPhx's Avatar
The AFR 225's with the 72cc chamber would certainly help and increase power along the way, but are spendy. Otherwise the standard 6.0L Gen III heads have a 71cc chamber but will sacrifice some flow compared to the LS6/LS2 head.
Old May 17, 2006 | 09:19 PM
67camaro's Avatar
LS6/LS2 heads have the same intake/exhaust ports as 6.0L heads.
Old May 18, 2006 | 05:39 AM
EPP's Avatar
EPP
Patriot Performance LQ9 heads would work really well for what you are looking to do. Bob
Old May 18, 2006 | 10:21 AM
mr2guru's Avatar
Also PRC will do their stg1 cnc port on 317 heads too. Probably for the same price or cheaper.
Old May 19, 2006 | 03:36 PM
Gunnar@Patriot's Avatar
Our LQ9 heads are a great option for this application. We can do a set of these heads loaded with Patriot Gold springs, Ti retainers, Super 7 locks, bronze guides, Ferrea valves... all the best parts, for only $1295.00 !! Give Bob @ Exotic or any of our retailers a call and they will get you fixed up.
Old May 19, 2006 | 04:08 PM
org's Avatar
org
Question
Information put out by a number of sources indicate the 6.0L truck heads are the same as LS6 except for chamber size....so it would seem you'd sacrifice nothing while accomplishing the compression reduction. Right or wrong?
Old May 21, 2006 | 04:26 AM
caindo's Avatar
org, i agree. i think i'll be going with the sierra 2k2 year heads and some proper gaskets and achieve ~9.6:1 and lose no performance (sans the CR drop). that year of head is also rumored to be the most effecient, stock for stock.
Old May 21, 2006 | 05:38 AM
Bring the Noise's Avatar
http://store.summitracing.com/partde...5&autoview=sku
Patriot 2019 - Assy 2.08"/1.60"/72cc $1,195.95 and in stock (it would probably take a week at most to be on your doorstep).
Yeah thats 2.08in intake and 1.60 exhaust Ferrera Valves with .650" Gold Springs and alls the trimings.... very hard to compete with.
Oh and the kit should have head gaskets and bolts (will need longer bolts then what comes in the kit for the LS2, IE all the bolts need to be long not 3/4 long 1/4 short... check with a mechanic to see what I'm talking about).
Sorry Gunner... Summit keeps put'n your products out a lower price then your MSRP...
Old May 21, 2006 | 01:01 PM
1LoudTA's Avatar
thats a sweet deal damnnn
