LS7 427 Short Blocks @ SDPC
LS1Tech Co-Founder
Originally Posted by stang90gt50
I think I mean its overpriced for the factory to charge $3k for a block that cost minimally more to cast than a LS2....Same block essentially with larger bore...
The GM C5-R block is $6K if that makes you feel better
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
This LS7 combo is amazingly priced, stuff like this would have been $10K only 5-6 years ago.
LS1TECH & Trucks Sponsor
Originally Posted by DavidNJ
How much are the rods and crank?
Eagle Crank
Scat "H" beam rods
Manley Custom Pistons
Clevite "H" series bearings
Total Seal Classic file fit rings.
Balanced.
Originally Posted by bg-sdpc
The rotating assembly that we use sells for about $2200.00..
Eagle Crank
Scat "H" beam rods
Balanced.
Eagle Crank
Scat "H" beam rods
Balanced.
Eagle Crank
Scat "H" beam rods
Balanced.
Eagle Crank
Scat "H" beam rods
Balanced.
What about the LS7 Ti rods?
Note: Pricing is not that bad on them either. We will have them for around $760.00 a set.
Brian
#33
We are not using the LS7 factory rods because the are not readily available at this time and also we have not had a chance to do any testing with them. Do to these factors, at this time we are going to stay with what we have been using for rods.
Brian
Brian
#34
Originally Posted by CHRISPY
What would the price on this be as a complete longblock? LS7 heads, LS7 intake, custom cam etc?
Cheers,
Chris
Cheers,
Chris
#35
man i really want a short block like this but if i was going to build one i would probably opt to get some Lunati rods and crank because when you that big a motor it would just make me feel better haha
#37
Originally Posted by restoman45
is it possible to get the actual ls7 short block from you guys?...aka the ls7 crank, rods, pistons...?
Brian
#38
Brian
#39
what all would be needed to drop this in a c5 z06? say someone has the ls7 shortblock, gets a pair of ls7 heads(btw, do you guys have those yet?), ls7 intake & TB. i'm talking engine mounts, oil pan, engine accessories & misc like oil pump, water pump, thermostat, and so on
#40
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
This is a killer deal for a 427 shortblock. Granted, it's not cheap, but no Gen III/IV 427 is cheap. Another thing to consider is SDPC engines are built by a machine shop owned by SPDC who builds Pro Stock motors. They know how to build motors. If I'm wrong about that SDPC can correct me, but when I bought my LS2 402 from them in Jan-05 that's what Kris Jones told me.
