LS7 427 Short Blocks @ SDPC
Old May 19, 2006 | 09:34 AM
bg-sdpc's Avatar
LS1TECH & Trucks Sponsor
Default LS7 427 Short Blocks @ SDPC
As I posted earlier, we have started getting the LS7 blocks in stock so we are going to start production on the 427 short blocks. They will come with the same components that our 402 LS2 comes with including the LS2 front cover, valley cover, timing chain dampener and timing set.
$6295.00 plus shipping.
If you want one, get your order in now so you can be next in line to get a block.
Brian (806) 798-4000 ext 354
Old May 19, 2006 | 10:11 AM
dhdenney's Avatar
Pardon my ignorance, can this short block be wet sump? Or is it dry sump only since it's a production LS7 block?
Old May 19, 2006 | 10:35 AM
bg-sdpc's Avatar
We are going to set it up for wet sump.
Old May 19, 2006 | 10:40 AM
adams2003's Avatar
Is it correct to say that the ls7 is a resleeved ls2 block? Or are there any other differences that im unaware of?
Old May 19, 2006 | 11:06 AM
dhdenney's Avatar
I'm guessing it's a similar but different casting. Note that Brian said they would "set it up for wet sump." The LS2 is already wet sump. But perhaps the more knowledgeable will chime in.
Old May 19, 2006 | 11:09 AM
NOSjohn's Avatar
Restricted User
Very nice !
Old May 19, 2006 | 11:47 AM
CHRISPY's Avatar
What would the price on this be as a complete longblock? LS7 heads, LS7 intake, custom cam etc?
Cheers,
Chris
Old May 19, 2006 | 12:02 PM
Z O SICK's Avatar
Cheers,
Chris
That's what i want to know. I'm guesing it cant be anymore than a LS7 crate motor.
Old May 19, 2006 | 12:39 PM
stang90gt50's Avatar
Man....talk about over priced ouch.
Old May 19, 2006 | 12:40 PM
Katech_Jason's Avatar
LS1TECH Sponsor
You've got to be kidding.
Old May 19, 2006 | 12:57 PM
CHRISPY's Avatar
You are kidding right?!
Old May 19, 2006 | 01:51 PM
blaksabb's Avatar
Are you thinking bare small block? The short block is chock full of goodness. I'd be willing to pay another $1-2K more to replace the Eagle internals w/ some quality Lunati or Callies stuff (billet crank, anyone?).
Old May 19, 2006 | 02:28 PM
67camaro's Avatar
wouldnt the use of the LS7 crank lower the price?
Old May 19, 2006 | 02:54 PM
Richiec77's Avatar
The block alone is $3,000 or 3100. There is a thread in here just below this one where SDPC announced the pricing for the block.
Old May 19, 2006 | 05:54 PM
bg-sdpc's Avatar
The LS7 crank has a .883" longer snout for the drysump pump. This moves the balancer forward so you have to use LS7 front brackets.
Brian
Old May 19, 2006 | 07:54 PM
Richiec77's Avatar
Ah. So the way you can convert the LS7 block to a Front mounted Oil pump is to use an aftermarket pump. Good info man.
Old May 19, 2006 | 08:20 PM
Order 66's Avatar
I hate not having money to blow. Awesome price.
Old May 20, 2006 | 01:36 AM
I think I mean its overpriced for the factory to charge $3k for a block that cost minimally more to cast than a LS2....Same block essentially with larger bore...
Old May 20, 2006 | 01:37 AM
adams2003's Avatar
Yeah but aything with that size of a bore from gm or aftermarket is atleast that much.
Old May 20, 2006 | 02:47 AM
Nah...factory 400 SBC's used the bigger bore...too bad they stuck them in trucks.
