Ls6 to ls2 cam sensor.
Old May 28, 2006 | 10:25 AM
linn.35's Avatar
Default Ls6 to ls2 cam sensor.
I keep getting cam sensor high freq. code on my car now since I did the swap. Does the ls2 have a higher frequency then the ls6. This is a ls2 402 short block.
Old May 28, 2006 | 10:34 AM
Katech_Jason's Avatar
LS1TECH Sponsor
What cam gear are you using?
Old May 28, 2006 | 11:03 PM
linn.35's Avatar
LS2 cam gear. It came with the 402 ls2 short block.
Old May 29, 2006 | 01:56 AM
LS1TECH Sponsor
What year?
Old May 29, 2006 | 06:04 AM
Bring the Noise's Avatar
Uh the LS6 cam sensor is like the LS1 (on the cam)
the LS2 cam sensor is on the Cam GEAR (not on the cam).
Just a though
Old May 29, 2006 | 06:45 AM
Bill Reid's Avatar
What cam gear are you using? The one on the left or the one on the right? When you did the swap and bought the LS2 cam sensor what year did you specify? What year is the vehicle? ...then get back to Jason
Old May 29, 2006 | 09:57 AM
DrkPhx's Avatar
The one on the left is the original LS2 sprocket (same as the one in my LS2 402), the other one is the LS7 sprocket is also used on later LS2's when they switched the crank reluctor wheel and PCM. Either one should work, but if I had my pick I would choose the LS7 version.
linn.35 - Did you swap the cam sensor wires?
Old May 29, 2006 | 10:22 AM
LS1TECH Sponsor
No, the 4x will not work.
Old May 29, 2006 | 10:53 AM
DrkPhx's Avatar
Question
Jason - You have me confused. Please clarify which is one is the 4X gear. Because I have the one on the left.
Old May 29, 2006 | 11:11 AM
ramairws6's Avatar
Sorry to go off topic here but I have a question for Jason. Does Katech have anything or know of any company that sells a throttle cable bracket conversion kit to convert from Flybywire for a cable operated TPIS throttlebody on a LS7 intake? Traver
Old May 29, 2006 | 11:19 AM
linn.35's Avatar
Well here is the problem. I had a friends shop do the short block swap. They ordered me a 402 from SDPC and everything needed for it. I cant get ahold of them to find out which cam gear they ordered. I know it was an upgraded one though. I will have to call SDPC tomorrow and find out since they are not open today. And i know that there was a new ls2 sensored installed. What issues could I be looking at from this code or what problems.
Old May 29, 2006 | 12:27 PM
linn.35's Avatar
Here is what I found out so far. The cam gear is a N-motion cam gear for ls2.
Old May 29, 2006 | 12:50 PM
LS1TECH Sponsor
The cam gear is a N-tech cam gear for all late model ls1-ls2 cars.
This statement doesn't really make sense because cam gears are different between LS1/LS2.
Old May 29, 2006 | 12:53 PM
LS1TECH Sponsor
We have been using UMI throttle bodies exclusively but it presents the same problem. We fabricated our own throttle cable bracket.
Old May 29, 2006 | 12:54 PM
linn.35's Avatar
ok sorry i fixed my above post with pics
Old May 29, 2006 | 01:07 PM
LS1TECH Sponsor
Hard to tell from the pic, but is that the side you see when it is installed?
Old May 29, 2006 | 01:28 PM
linn.35's Avatar
No that is the cam side that you see in that pic. Also do the cam sensor wire colors match on do they not match. Do I need to swap the colors. Also are people using the factory cam sensor extender wire or do we plug it directly into the sensor itself. Here is what I am confused about. http://www.cajundude.com/engineswap6.htm
This paragragh...
Now, if putting in an LS2, you will need to extend the cam sensor wires. On the LS1, the sensor is located behind the intake. The LS2 block comes with the sensor mounted on the front. It is the one with the black bracket. NOTE that the outer wires are reversed between the LS1 and the LS2. In other words, the colors will not match up so you need to swap these. I just bought the right color wire, as I did for the knock sensors, and cut the plug off of the car and put away in a drawer. I then cut the new plug off of the front location and extended the wires to it. That way there is no mistake on mixing the wires up. Solder and heat shrink all of your connections. I also ran the wires in a 1/4" taped up wire loom. If you will be reusing (you don't have to) the black bracket on the front, replace it now. I separated the metal a little to allow the loom to fit inside the channel. Once the engine was in and it was plugged in I wrapped tape around to trap the loom. You can see the plug and black bracket next to the balancer in this pic.
Old May 29, 2006 | 01:30 PM
LS1TECH Sponsor
This paragragh...
You're getting ahead of yourself with the wiring. First, what does the other side of the cam gear look like?
Old May 29, 2006 | 01:50 PM
linn.35's Avatar
it has the half ring on it...not 4 marks
Old May 29, 2006 | 01:51 PM
LS1TECH Sponsor
Ok, are you extending the cam wires yourself or have you purchased a plug-and-play harness?
