Ls6 to ls2 cam sensor.
Old May 29, 2006 | 01:58 PM
linn.35's Avatar
plug and play from sd
Old May 29, 2006 | 02:00 PM
Katech_Jason's Avatar
LS1TECH Sponsor
Check the colors of the A and C terminal wires at each end of the cam extension and make sure they switch.
Old May 29, 2006 | 02:05 PM
linn.35's Avatar
ok
cam sensor side
a=brown
b=pink
c=red
harness side behind intake
a=brown
b=pink
c=red
so its the same on both sides
Old May 29, 2006 | 02:52 PM
LS1TECH Sponsor
ok
cam sensor side
a=brown
b=pink
c=red
a=brown
b=pink
c=red
I'm not at work right now but if I remember correctly A and C should be reversed.
Old May 29, 2006 | 02:54 PM
linn.35's Avatar
Ok will do that and see what happens. I appreciate your help alot.
Old May 30, 2006 | 05:31 PM
2ktransam's Avatar
I am having the same problem. How did you guys get the wires out of the plug or did you just cut them to do the switch?
Old May 30, 2006 | 05:36 PM
LS1TECH Sponsor
There is a special tool to release the terminal. I verified today, it is A and C.
Old May 30, 2006 | 06:42 PM
2ktransam's Avatar
Is this special tool something that you can pick up at Advance or Autozone?
Old May 30, 2006 | 06:51 PM
LS1TECH Sponsor
I've never seen one at an Autozone or Advance, but then again I've never looked. This is what they look like. You can buy right from Caspers and they are an LS1tech sponsor.
https://www.casperselectronics.com/M...gory_Code=conn
Old May 30, 2006 | 09:26 PM
linn.35's Avatar
Switching the wires fixed my cam sensor code problem. Now time to get a good decent tune on her.. Thanks Katech...
Old May 30, 2006 | 10:27 PM
LS1TECH Sponsor
Glad to help
