LS7 intake manifold with ETP C5R heads, will the intake fit?
The GM C5R heads have the incorect bolt hole placement so the intake won't bolt up. However, I'd bet that if the LS7 intake port size was sufficent, ETP could set the C5R style head to accept the factory bolt pattern. Benefits of having a blank casting to start from!
Originally Posted by Abdullah
thanks for info. i feel the C5R heads are better than LS7 heads, am i correct in that?
aren't the LS7 heads a 12* heads where the C5R heads are 11* heads?
The Flow numbers will be provided
Ask Craig.
Craig @ ETPerformance
E-mail Address(es):
craig@etheads.com
Good Luck
John Sr.
Originally Posted by cary et performance
we do machine the ls7 bolt pattern in our c5r as a standard unless requested otherwise.
chambers
thanks for the info. is there more chamber volume options for the et C5R heads other than the 58cc chambers? i mean like if i wanted 72cc chambers?
