Finalizing LS2 Build and Need some expert help
http://www.alantripp.com/VE Calculat...igy Lookup.xls
2003 Z06 with LS6 intake and ported TB for now, and LT headers with hi flow cats and no mufflers
LS2 4.03 bore/4.00 stroke (408 cu. in.)
Cam 238/242 .605/.610 112 +4
Dart 225 milled to 59 cc chambers
Mahle 12 cc dish piston (.010 out of the hole)
.045 Cometic gasket
The calculations I get are:
quench .035
SCR 11.14:1
DCR 8.44:1
IVC 47 at .050
EVO 57 at .050
Overlap 16 at .050
Bumping the LSA to 114 will decrease DCR to 8.35 and overlap to 12 while increasing IVC and EVO 2 degrees.
I drive the car daily but put about 25% of the miles on the car on a road course like Sebring running rpms 3500-6800. I don't mind a good lope, but do not want stalling. A proper functioning a/c is of utmost importance.
So, what do you think? Any cam changes? Any milling or gasket changes? Also, will flycutting be needed? Thanks.
Bill
http://www.rbracing-rsr.com/compstaticcalc.html
In that you are going to run road courses I would consider a C6 oil pan as it is much better re oil starvation in corners.
Can the head guy address the angle of the mill?
I gave up on a FAST so I am not an impartial observer.
You will also need some ~>40# injectors.
Some calculators ask for out of the hole value and with others you can deduct out of the hole from gasket thickness.. One way or the other it is a big player.
More like: 238/242 .605/.610 110LSA (+1)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
From the info I got from several builders of LS2 motors using the Mahle pistons is a deck height of .005-.012 out of the hole depending on whether the block is decked or not.
