Starting my Mamo Ported FAST90/NW90 + Custom Ground Mamo Cam upgrade in LS2 402.
#41
What kind of dyno numbers are you 402 guys putting down??
Congrats on getting your car where you want it! Tony is definately a stand up guy and is more than willing to help us less knowledgable guys out anytime he has a chance!!!
#42
It was pretty much determined by all the cam experts on this board that that is not the correct cam for the 402 due to where the valve events happen. I figured that I would just swap it out as it was the recommended mate for my new setup. Maybe someone else can give a more technical explanation.
#43
#44
Originally Posted by 98Z28CobraKiller
Ahhh. Gotcha. I was a little confused (which is n't hard to do with my limited knowledge of cam timing).
and retard the cam and you move the torque band up.
If you have to move the cam more than 6-7 degrees, then you have the wrong cam.
DoC
#46
First, thanks for doing all this for us 402 guys, 98Z28CobraKiller!!!
Amazing dedication, thanks!
Billy at CC will be choosing my specs and cam for my St. Louis tuner/CC distributor and me...
Very interested in getting my FAST 90 Mamofied...hook me up? How much?
(I need to change my sig, Going with RHS 5 degree 225 heads, T&D rockers and Billy's custom cam for my heavy chevy. )
Thanks,
Ram
Thanks,
Ram
#47
Originally Posted by pdd
great thread-thanks for the pics and info
What's going on with your new AFR 205's??
You have had the heads almost a month already!!
(sorry to slightly hijack Carlos's thread!)
Looking foward to some results....hopefully it's a when the smoke clears. Don't forget these heads might want a completely different fueling and spark table to maximize their performance.
Rambo, I PM'ed you BTW.
Regards,
Tony
Feel free to PM me and let me know whats happening...
#49
LS1 Tech Administrator
Originally Posted by Billiumss
Hey Tony (AFR),
Do you hand port the FAST intake or do you use a CNC program to do the porting?
Bill
Bill
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
#53
I have been following a few of your threads with your 402 builds and just curious if you have any new numbers or updates with the new cam and intake. I am basically in the same situation as you, just trying to figure out what cam I want to switch over to.
#54
Latest update is that I did finally get my hands on the WBO2 but my buddy did not give me the serial cable with it that I need in order to setup the voltage correctly in order to log thru HPT and the EGR connector. I hope to have this tomorrow. I have been fighting the 98' KR bug also.
Prior to this delay, I had another delay where I snapped 2 of the studs in my rear right wheel. I had to wait for the new longer/harder wheel studs to arrive. Since I was going to be jacking the car up in the rear to get the new studs in, I ordered a new pan hard bar and some tubular lower control arms (fixed the clearance problems with my 15X10 wheels and my 325 50 15 rear tires).
#56
I was also considering this one from Patrick G: 243/251 .653/.660 110LSA +2
what springs would i have to run in order to run this cam? or is this a solid roller set up?
im looking real hard at the dart 225 head milled .030 and .030 cometic gaskets on my LS2 403..... as of right now static compression is 10.8:1 if i were to reuse my stock LS6 heads unmilled. im repeating what i can remember from what the builder told me. diamond pistons -2cc with valve relief cuts that make the pistons -11cc i believe, id have to double check.
#57
__________________
#59
Originally Posted by Patrick G
Those are Comp LSK hydraulic lobes. You'll need to run a good spring like a Comp 921 shimmed to within .050" of coil bind.
i think i am going to run it. i have seen you suggest this a number of times and suggested it to me in a previous thread a couple of months ago.
what about running less lift, what changes would be made to the duration if any?
the shop that built my short block, suggested running .608/.621 242/250 112+4, with their CNC LS6 heads
