Katech Torquer LS7 Cam now available
Old Nov 28, 2006 | 08:14 PM
black_knight's Avatar
Originally Posted by AU N EGL
and arn't LSx intakes and heads desigend for max tq about 4400-4800 and max hp at 6100-6300 so yes you are correct that there is no reason to spin up to 6800 rpms.
I'm guessing the LS7 heads and intake are a different animal... Katech, any word on what RPM the LS7 stuff peaks at?
Old Nov 28, 2006 | 08:59 PM
Wnts2Go10O's Avatar
that would be a nifty cam in my l76 clone
Old Nov 28, 2006 | 11:08 PM
White_Hawk's Avatar
Somebody stick this in their 402 with L92 heads and L76 intake. I don't want to spend $500 to be the guinnea pig!
-Geoff
Old Nov 29, 2006 | 09:53 PM
Nate_Taufer's Avatar
For whoever cried about the power drop, shifting this cam at 6000 would be a waste. You could shift this combo at 6800 and it would flat out haul.
Nate
Old Nov 30, 2006 | 01:03 AM
Bring the Noise's Avatar
Another person interested in what this cam would do in a L92 / L76 stroker.
Since the L92 head was based off of the LS7. A cam designed for an LS7 that was put into a L92 or L76 stroker (402 to 418) should come close in hp/tq numbers.
Especially if the LS7 heads were stock on that dyno run -vs- a set of cnc ported L92 heads.
I'm guessing the springs & retainers you list for this upgrade would also be usable for a set of L92 heads.
I'm guessing the lift numbers are for 1.8" rocker arm's and would drop down to roughly .580" intake and .612" exhaust when using 1.7" rocker arm's for a L92 setup.
_edited for typo's and that long azz run on sentence_
Old Nov 30, 2006 | 01:53 AM
Why? It's designed for the LS7. If you want to run a cam for the L92/L76, then get a cam designed for that.
Old Nov 30, 2006 | 04:47 AM
BK think about what I'm talking about.
L92 heads are based off of the LS7 head. Basicly scaled down slightly and changed up from a 12 degree valve angle a 15 degree valve angle.
People are putting that head (strait or slightly ported) onto LS2 or L92 Strokers that put the cubes inbetween the 402 to 418 area (just short of a stock LS7).
Hmmm the cubic inches are just short of a LS7 with a head that is designed from the LS7 head...
Simple logic should tell you that on a 400+ stroker built with L92 heads the LS7 based cam's would give very good results (it should be very close to how a built LS6 compares to a built LS2 with the same heads and cam). Especially when compared to the same motor running a LS1 based cam.
90% of all the LS1 based cam's don't seem to have the extra exhaust duration to match up to the L92 heads. This cam's design looks to have more then enough duration to make a set of L92 heads run good on a Stroker setup.
Oh and not to mention the fact that the L76 low profile manifold seems to flow better then a Fast 90 but a little lower then a LS7... and it's designed very very similar to the LS7 manifold (differences being its for mass mass mass production and its 1 piece molded unit).
Old Nov 30, 2006 | 05:41 AM
Quik's Avatar
um very interesting
Old Nov 30, 2006 | 09:37 AM
Ratical's Avatar
Will this cam have clearance issues on an LS2 402 motor without flycutting?
Old Nov 30, 2006 | 09:48 AM
Katech_Jason's Avatar
LS1TECH Sponsor
likely yes
Old Nov 30, 2006 | 09:55 AM
Ratical's Avatar
Bummer.
Old Nov 30, 2006 | 02:18 PM
  #32
WizeAss's Avatar
Originally Posted by Katech
likely yes
WHAT ABOUT -10 CC VALVE RELIEFS?
Old Nov 30, 2006 | 02:25 PM
  #33
LS1TECH Sponsor
I need to know vertical valve drop.
Old Nov 30, 2006 | 02:26 PM
  #34
LS1TECH Sponsor
I'm not really sure what you're asking here.
Old Nov 30, 2006 | 02:32 PM
  #35
NoGamesLS1's Avatar
That dyno is rwhp not fwhp correct? Either way unbelievable!!! Esp with just a 220 cam
Old Nov 30, 2006 | 02:42 PM
  #36
LS1TECH Sponsor
Engine dyno
I hate chassis dynos.
Old Nov 30, 2006 | 03:00 PM
  #37
ATVracr's Avatar
I've never seen a 402 without valve reliefs
Old Nov 30, 2006 | 06:38 PM
  #38
WizeAss's Avatar
i always thought that if you do the right custom pistons w/ the proper notches you wont need to flycut the pistons ???
as far as verticle drop....... ya got me on that one. I have not seen the heads on a bore in person nor do I have access to a set... so as far as where the 2.16/2.18 etc intake valve at .650 or so lift matches to the piston .... no clue.
I wonder how close on the bore the valves get and what size reliefs are needed for this setup without compromising compression??????? to be determined..... Man people need to get on the stick.
I like these options alot more than buyin AFRs etc.
Old Dec 1, 2006 | 03:14 AM
  #39
The guy I was responding to was trying to equate the torque peak that LS1's tend to have due to runner length with the LS7 and speculating that the LS7 might "like" the same RPM range. Of course, since LS7's have different cubes and runners, this is silly.
But I was wondering that given 427 cubes, LS7 heads and intake, and presumably long tube headers, if there was a particular RPM range that the LS7 curve "likes" to peak at. I was under the impression that a given runner length would do this, but I could be completely off base here...
Old Dec 1, 2006 | 08:42 AM
  #40
LS1TECH Sponsor
In a recent cam test torque peak for all cams was 4400-4800rpm.
