Katech Torquer LS7 Cam now available
Old Dec 1, 2006 | 09:57 AM
  #41
Ratical's Avatar
Originally Posted by ATVracr
I've never seen a 402 without valve reliefs
Sorry, I meant because of the bigger valves, would I need to enlarge the reliefs.
Old Dec 1, 2006 | 06:12 PM
  #42
black_knight's Avatar
Originally Posted by Katech
In a recent cam test torque peak for all cams was 4400-4800rpm.
Thank you. That answers my question.
Old Jan 7, 2007 | 01:00 PM
  #43
Katech_Jason's Avatar
LS1TECH Sponsor
Note:
The Torquer LS7 cam now has 4 degrees advance built in.
Old Jan 7, 2007 | 01:01 PM
  #44
52172's Avatar
where does it usually make peak power with and without the advance. Thanks.
Old Jan 7, 2007 | 01:20 PM
  #45
DoesSpeedTurnUon's Avatar
Note:
did it not have it in the dyno posted on page one? Would this increase the RPM band?
Old Jan 8, 2007 | 09:21 AM
  #46
LS1TECH Sponsor
6000 but barely drops off until 6400
Old Jan 8, 2007 | 09:25 AM
  #47
LS1TECH Sponsor
The dyno on the first page is without the advance. It increases torque about 6 lb-ft and sacrifices about 4hp.
Old Jan 14, 2010 | 08:16 AM
  #48
Bowtiejoni's Avatar
Sorry to bother with stupid question but is there now "new" torquer cam vs older without added advance?
Old Jan 14, 2010 | 08:20 AM
  #49
LS1TECH Sponsor
Wow, this thread is back from the dead.
The new torquer cam is the one with 4 degrees advance built in.
Old Jan 15, 2010 | 12:50 PM
  #50
MGGLS1's Avatar
Thumbs up
I just got my car dynoed today at Virginia Speed and Ed said it made 520 rwhp with the original torquer cam.
I switched to the torquer cam after having a 243/253 on a 113 with .650 or so lift. The Torquer Cam completely transformed my 427 ls7. It has so much more torque now that you can't even compair the two. Its like a whole different engine and MUCH more enjoyabel to drive on the street now.
I drive my car 99% on the street and feel as though this is an excellent cam and worked exactly as advertised. I have never felt a drop off at high RPM (rarely go that high anyway), and the driveability is very much improved.
Just my 2 cents, but now that this thread is back, I just wanted to give my thumbs up!!!
Matt
Old Jan 15, 2010 | 02:59 PM
  #51
LS1TECH Sponsor
Matt
Thanks for the feedback. I'm glad you like it.
Old Jan 16, 2010 | 09:47 PM
  #52
GIGAPUNK's Avatar
I was trying to figure out what DCR the torquer would put a stock LS7 at, but then i remembered that you guys use proprietary lobes. What DCR does the torquer put a stock LS7 at? I'm guessing well above 9.1
no?
Old Jan 18, 2010 | 02:39 PM
  #53
LS1TECH Sponsor
no?
I'm getting a couple different numbers using two different calculators, so I'll just give you that data. IVC is 36 deg. ABDC and the rod length is 6.067.
Old Jan 24, 2010 | 02:14 PM
  #54
MGGLS1's Avatar
Default Final dyno
After switching to a PowrMax 100mm MAF, Ed at Virginia Speed churned out these final numbers.
Remember this is through a Ford 9inch with 3.70 gears.
The engine is a 430 with 11.5 to 1 compression and a ported intake and etb.
Matt
