Katech Torquer LS7 Cam now available
PN# KAT-4727
$500.00
220/244 @ .050, .615/.648 lift 110LSA
We have this cam in our Z06 vehicle packages and it's a rocket. It feels much faster than our 640hp Camaro because the torque comes on so fast and so strong. It also idles and is very drivable.
Requires upgraded springs $16/ea (65 grams)
titanium retainers KAT-4678 $16/ea (5.5 grams)
PN# KAT-4727
$500.00
Nope, its just great. We decided to trade off some peak power and redline power for a lot of torque a lot of drivablity. I've driven both cars and I'd definitely make the trade-off if it was my car.
I am faced with a simmilar dilema with my setup... I have a choice between 2 cams that look somewhat like your Street Attack and Torquer... my car is stalled A4 with a converter that flashes in the 4K range... If you could post a dyno overlay of both cams that would be great! My car spends 90% of it's life at the track, so I don't mind sacrificing some driveability...Is it safe to say the Torquer Z06 makes about 500RWHP?
-Geoff
-Geoff
BTW: im putting it in my 92 Sonoma GT with a T-56 backing it up.
Thanks
EDIT - Just a heads up to Katech, the specs on you website for the cam are wrong, on the site it's listed as: 220 / 224 @ .050, .615 / .648 lift, 110 LSA ....
Thanks for the heads up on that typo. I'll be fixing that tomorrow.
This cam was developed just for the LS7. I don't have any data for a 364.
Hey, I don't mean to nitpick but whenever you post up dyno numbers, you should make it loud and clear whether the numbers are at the crank or at the rear wheels. I see this is at the crank; i.e. flywheel horsepower, engine dyno, etc.
Which kind of stinks for this site since we are all used to seeing rear wheel numbers and corrections factors are always to be taken with a grain of salt.
HP is a caculated funtion of TQ where HP=TQ at 5252 rpms
HP = ((TQ x rpms) / 5252 )
and arn't LSx intakes and heads desigend for max tq about 4400-4800 and max hp at 6100-6300 so yes you are correct that there is no reason to spin up to 6800 rpms.
The higher the low end tq 2400 to 4800 the quicker off the line or out of corners.
