Katech LS7 Pistons
Old Jul 24, 2006 | 08:26 PM
Lythropus's Avatar
Default Katech LS7 Pistons
I read on another board that Katech will be offering low compression pistons for the LS7 in feburary. Is this true? If so, what is the compression ratio with stock heads? What other internal upgrades are offered for the LS7 to make it more boost reliable? Also if a twin turbo setup is added how strong is the block compared to a wet-sleeved LS2?
A very long detailed explanation would be great. Thanks in Advance.
Old Jul 25, 2006 | 07:46 AM
Katech_Jason's Avatar
LS1TECH Sponsor
Yes, they are a 9.0:1 piston that uses Katech - Carrillo A-beam steel rods.
