L92 results?
Old Jul 27, 2006 | 03:58 PM
Stang's Bane's Avatar
Default L92 results?
Has anyone actually finished a build using these heads? If so, what kind of power did it make. I am looking to save a few bucks on my build and I think this may be a good way.
Old Jul 28, 2006 | 05:47 AM
Nobody huh? what if you gotthe heads on and are just waiting on a manifold.
Old Jul 28, 2006 | 10:05 AM
Richard@WCCH's Avatar
I think most guys are waiting for a factory plastic car style intake to become available. At the moment the only intake available is the truck style for the '07 Escalade.
We'll be working on a CNC program for the heads in the near future. That should help gather some interest with these new heads. I hope to have the program done in time to coincide with the release of the Aussie (car style) intake.
Good luck,
Richard
Old Nov 5, 2006 | 09:18 AM
Richard, do you have the CNC program developed yet, or are you still working on it?
Old Nov 5, 2006 | 10:50 AM
I'm still working on it. I hope to have it ready by the first week in Dec.. Stainless valves won't be readily available until at least then as well.
Richard
Old Nov 5, 2006 | 12:34 PM
skipperbisket's Avatar
why wouldn't you stick with the stock valves that come in the heads? are they not big enough?
Old Nov 5, 2006 | 01:22 PM
Rock_Daddy's Avatar
Damn I've had a motor done for what seems like forever but the car isnt ready enough to chassie doyno it yet.
Old Nov 5, 2006 | 01:57 PM
rock_daddy, why did you go with sucha a small cam with an otherwise sweet setup?
how much did those Howards rods set you back?
Old Nov 5, 2006 | 02:02 PM
Rock_Daddy's Avatar
W2W picked the cam themselves. As some have said before with the big valves and large flow I guess a huge cam isn't as needed maybe as we are used to with other heads, it's all a guess still I'm sure. Billy at W2W told me not to worry, it will fly.
The Howards rods, JE pistons and Callies crank were also W2W's suggested parts. I think the entire rotating asemble cost around $3200 but I don't know the cost of the rods specificly. I just gave them a crate motor and a big check and said make it go fast. We shall see.
EDIT: Actually I expected a 228/234 588/598 cam as that is what I was told it would be but I just found out the other day the cam card in my file there was what I posted in my sig. I was a little disapointed at first but it is what it is. I have a second set of heads I'll get ported when they get figured out and if I really feel the cam is too small I can always change it. I bet it still flys and I should be able to spray into it if needed.
Old Nov 5, 2006 | 05:12 PM
Considering the cost vs performance and durability I prefer to use forged 1 piece stainless steel valves.
Richard
Old Nov 5, 2006 | 05:23 PM
WKMCD's Avatar
Richard
Won't stainless valves cause futher P/V problems?
Old Nov 5, 2006 | 10:19 PM
Not sure I follow. If your refering to piston/valve interference, there will most likely be less clearance than an OEM valve.
Richard
Old Nov 6, 2006 | 05:56 AM
WKMCD's Avatar
Richard
Richard, thanks for figuring out my late night question.
On your heads, will you be seating the valves a little further in the head to make up for the thicker SS valve?
Old Nov 6, 2006 | 09:10 AM
We'll be remachining the seats and therefore lowering them a small amount. I can't tell you what the net amount will be until the valves are available.
Richard
Old Nov 6, 2006 | 12:07 PM
gun5l1ng3r's Avatar
Are the SS valves any heavier than a standard valve?
And will titanium or sodium filled valves be available for high RPM use or will the SS valves be fine to 7K RPM?
Old Nov 6, 2006 | 05:27 PM
Sometimes. They usually have more mass at the edge of the valve but may a larger dish in the chamber or a flatter under head angle that will reduce the overall weight. It will be dependant on the valve manufacturer as to the weight of a particular valve. Sorry I can't be more specific here.
Richard
