New GMPP LSX Block
Old Jul 30, 2006 | 07:20 PM
See5's Avatar
Wegner is about to ship 400 new L92 carb intakes to the General for a crate engine coming out very soon. GM funded the development.
Old Jul 30, 2006 | 07:34 PM
firefighter's Avatar
Have they ever gotten the Aussie intake?
Old Jul 30, 2006 | 07:45 PM
Bink's Avatar
SDPC is supposed to have the Aussie intake bundled with L92 heads - soon. At least that was what I read in.......HPChevy
Old Jul 30, 2006 | 08:17 PM
TJ's Avatar
TJ
im ready for the l92 carb intake, then a set of heads, then some track times.
hahahaha.
Old Jul 30, 2006 | 11:10 PM
99SLOWC5's Avatar
I ahve pictures of the proto type block, but I dont think I should post them. I dont know much about the block. We had one made through rapid prototyping for GM. Only thing I knew was its designed for the racing division, or in conjunction with the racing team.
JEFF
Old Jul 31, 2006 | 08:37 AM
slt200mph's Avatar
Sounds great where and when can I get one..
Old Jul 31, 2006 | 12:49 PM
LSxChevelle's Avatar
So curious now!!!
Old Jul 31, 2006 | 01:05 PM
Stang's Bane's Avatar
Originally Posted by PewterWSSicc
I heard a bit about something similar to this that was in GM high tech performance. Let me grab the mag and ill post exactly what they said, if its not too long. This might be connected to what you guys are talking about. Its on page 10 of Aug06 issue. This is exactly as it is written.
"A little bird told us during a recent tour of a NHRA racer's shop, he spotted a set of "gargantuan" LS-style heads. When he asked the racer about them, the gentlemen stated, "I'm working on some LS8 program stuff for GM, and I got some preliminary castings." A huge LS-style block was also spied-it had a 4.300-inch bore and was set-up for 4.400-inch stroke, which would mean a massive 511 cubic-inch displacement! The racer stated he was playing with these parts to see what kind of power they would make, and said "This setup will make an easy 900hp."
A mention was made of this block becoming available through GMPP before long-and while that can't be verified, the racer stated "I don't get parts unless they're actually going to do something with them."
Doesnt sound exactly like what you guys are talking about. But could somehow be related. Either way, this would be kick ***. A 511 CI small block, no doubt though the cost would start very high, something like the C5R block.
Am I the only one that see's a problem with a 4.3 bore on a 4.4 bore spacing?
Old Jul 31, 2006 | 02:20 PM
1CAMWNDR's Avatar
I am wondering the same thing..................
Old Jul 31, 2006 | 02:36 PM
MrDude_1's Avatar
i was thinking that as i was reading it....
Old Jul 31, 2006 | 02:43 PM
I think that this has already been discussed. That big of a bore is not really possible. Even if you went to straight nikasil liners, it is still too much...
Old Jul 31, 2006 | 02:53 PM
  #32
XLR8NSS's Avatar
Adkoonerstrator
I saw that little blurb on the powerblock about the LSx block. The guy they picked to drive that bracket car said they would be putting in a LSX block that would be 454ci and should be somewhere around 1200hp. I don't know if that was supposed to be N/A or with some sort of power adder.
If GM comes out with a big bore block that is cheap they will have a hit on there hands. I don't care if it's iron, that's what's in my truck already.
Old Jul 31, 2006 | 04:06 PM
  #33
Anonymous's Avatar
10 second playa
Did anyone stop to consider that this may be the new Big Block block?
Look at the bore spacing. This is obviously a larger engine.
Warren Johnson races Big Blocks at 500 ci.
This may be the new DRCE block based on LSX architecture and may still be called an LS??.
JMHO
Old Jul 31, 2006 | 04:27 PM
  #34
Robin L's Avatar
LS1Tech Sponsor
Originally Posted by MGGLS1
I just saw Muscle Car TV on Spike, and they mentioned a new LSX Block that GM is working on. I have also seen it mentioned in quite a few magazines in the last week or so. It is supposed to be only $2,000 and that is about all they will say about it.
Does anyone have any more info on this block? Could GM finally be giving us an affordable large bore LS block?
Matt
The block is iron and will be capable of over 2000 Horsepower. Yes there is a rapid prototype just run for GM Performance Parts.
As I said on Spike's Powerblock the block was designed with Warren Johnson. It will be in the range that you talk about. I would not feel as though you can go past 4.250 without offsetting the bores. We will stay well below that to insure sealing between the bores.
I will have a block within a few weeks.
The Nova will be raced in the NMCA not the NMRA. It will use nitrous with a pair of dominators and a sheet metal intake. Plans include a Liberty 5 speed.
Currently the Super Nova is at the Team Z Motorsports shop in Flat Rock Michigan getting upgraded for next year.
Robin
Old Jul 31, 2006 | 04:35 PM
  #35
Haans249's Avatar
Robin
Wow, thanks for the update....pics please!
Old Aug 1, 2006 | 01:18 AM
  #36
black_knight's Avatar
...and a little bird says that a year later will come the aluminum version... no word on the price for that, though...
Old Aug 1, 2006 | 06:56 PM
  #37
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Capable of 2000HP FOR $2,OOO........?????????????
Old Aug 1, 2006 | 09:45 PM
  #38
"capable" is one of those vague terms... it might just mean the block is theoretically capable of that kind of power.
Old Aug 1, 2006 | 10:00 PM
  #39
UGotBeaT's Avatar
JMHO
No its not the new DRCE block.....they wouldnt even bother basing it on LSX "architechture"......
Old Aug 2, 2006 | 07:28 AM
  #40
Robin L's Avatar
LS1Tech Sponsor
It shouldn't be so hard to believe. Most aftermarket iron blocks are in that range. When I say range you should assume that it will be somewhere between $2000.00 and $3000.00.
Given the correct components the block is designed to handle in excess of 2000 horsepower.
I would predict that top of the line engine builders will squeeze somewhere in the neighborhood of 2500 horsepower.
The cylinder walls of the iron block will not distort like a sleeved production block that those power levels.
Of course it's not for everyone. It's nice to have a choice.
Robin
