LS7 intake rocker failure
Old Aug 1, 2006 | 11:43 AM
Haans249's Avatar
How would one go about screening the heads?
Adrian
Old Aug 1, 2006 | 11:57 AM
SuperSporttruck's Avatar
I talked to some one at ETP, and he said that Yella Terra has a set around 800.00, but I don't know for sure if they do. Someone may wanna do a little research.
Old Aug 1, 2006 | 12:18 PM
Haans249's Avatar
I would probably just get the stock LS7 rockers rebuilt. No need to spend 800 bucks.
Old Aug 1, 2006 | 05:57 PM
Dbl.0.Five's Avatar
Talk to howard @ Redline perfofmance I think he is a dealer for Curtisbilt rockers. He might have some info.
Old Aug 1, 2006 | 10:02 PM
gtovan's Avatar
Personally with what you have done so far with the ported LS7 heads and cam selection, I would bite the bullet and get the Jesel rockers and make it happen.
Old Aug 2, 2006 | 06:07 AM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Originally Posted by duke of cruel
I´m on my third set inlet rockers, because the rockers doesent look solid enough for performance. Thats in less than 10k miles. I dont have any failures on the rockers, i just changed them with servic, and to have been a bit crooked.
I didnt know that jesel had released rockers for the ls7 heads .
I hope that you didnt hav any following failures to the broken rocker, and hope you cleaned all debris out of the engine.
DoC
Hey Doc, how about posting up some pics of your setup?
Old Aug 2, 2006 | 09:46 AM
98blackSS's Avatar
I second that...
Old Aug 2, 2006 | 10:15 AM
SLED28's Avatar
There's no room for screens in these motors. The oil return runs down into the lifter area, not the valley area where you normally put the screens...
Old Aug 2, 2006 | 01:10 PM
CHarris's Avatar
Why not epoxy a couple of magnets in palces likely to catch crap. Easier than screens and more practical right?
Old Aug 2, 2006 | 08:46 PM
Drewman's Avatar
Originally Posted by Greg Fell
I dont want to use Jesels, they are great rockers, but $$$ and you have to machine the heads.
Sorry to hear about your rocker Greg. That sucks.
I bit the bullet and had Richard at WCCH machine mine for the Jesels when he enlarged the pockets for the new springs. The Jesels were $$$, but the machining was really cheap.
Old Aug 3, 2006 | 09:28 PM
TJ's Avatar
TJ
in a race engine, both is preferred, IMO.
