LS7 intake rocker failure
Old Jul 30, 2006 | 06:47 PM
Greg Fell's Avatar
Default LS7 intake rocker failure
Had one fail last night on #1. Spirited run then noise. Upon examination it looked like it failed at the fulcrum.
Has anyone else had one fail? Not sure if they are up to the task at hand, with my cam. Does anyone make any aftermarket ones, that are not $1400 Jesels?
Old Jul 30, 2006 | 07:24 PM
Haans249's Avatar
I was just wondering how the engine was doing. Are you running a solid roller with some large pressures on the springs that could have caused the fulcrum failure? Did you spill any bearings in the process? I haven't heard of any other rockers other then the Jesels, but you also have to machine the rocker stands to accept the shafts.
Is it possible for you to get a pic of the failure?
I hope all is well!
Adrian
Old Jul 30, 2006 | 09:03 PM
Greg Fell's Avatar
I run a hyrdaulic roller, with very aggressive ramp rates and a decent amount of spring pressure (#150ish on the seat). I'm sure needle bearings are all over now.
I dont want to use Jesels, they are great rockers, but $$$ and you have to machine the heads.
I can post some pics in a bit.
Old Jul 30, 2006 | 09:26 PM
Greg Fell's Avatar
http://74.136.106.154/DSC02773.JPG
looks like the heads gotta come off, the valve tip is beat up pretty good.
Old Jul 30, 2006 | 09:29 PM
stang90gt50's Avatar
What about harland sharpe's upgrade for the factory ls1 rockers, will that stuff go into a ls7 rocker?
Old Jul 30, 2006 | 09:47 PM
Haans249's Avatar
oh man, that is horrible. Were you running LSK lobes? I think I might get them rebuilt like you can the stock LS1 rocker arms. Yet, I can't remember who to send them into to get rebuilt...
Haans249's Avatar
i guess its harlan sharp
Old Jul 31, 2006 | 10:16 AM
NoRice's Avatar
see why us old timers screen our heads and blocks, you'd have to atleast drop the pan on that one
Old Jul 31, 2006 | 12:22 PM
gun5l1ng3r's Avatar
^ What do you mean?
Old Jul 31, 2006 | 12:34 PM
duke of cruel's Avatar
I´m on my third set inlet rockers, because the rockers doesent look solid enough for performance. Thats in less than 10k miles. I dont have any failures on the rockers, i just changed them with servic, and to have been a bit crooked.
I didnt know that jesel had released rockers for the ls7 heads .
I hope that you didnt hav any following failures to the broken rocker, and hope you cleaned all debris out of the engine.
DoC
Old Jul 31, 2006 | 12:53 PM
Greg Fell's Avatar
DoC
DOC, what size cam are you running? I think I'm going to change all 8 of them, and put a less aggressive cam in. I do not want to blow the motor apart.
Old Jul 31, 2006 | 01:16 PM
John B's Avatar
Moderator
Greg, PM me if you want details on machining the heads. It's not that much.
Old Jul 31, 2006 | 06:10 PM
383ss's Avatar
thanks for posting, good info. I haven't heard of any besides Jesels for ls7 heads
Old Jul 31, 2006 | 06:16 PM
Wnts2Go10O's Avatar
Originally Posted by gun5l1ng3r
^ What do you mean?
where ever oil drains back theres a screen or something like that. ive seen it a few times.
Old Jul 31, 2006 | 08:49 PM
Greg Fell's Avatar
after examining the valve in detail, i think i can just clean the face up, get a new thicker lash cap and all will be good.
it broke on the 'weak' side of the intake rocker...ie the side where the most load will be. maybe it was just a bad rocker...it'll be interesting to see how they hold up.
as for screening the heads/block, to catch those small needle bearings, i think i'd end up having oil control problems.
Old Jul 31, 2006 | 08:55 PM
Haans249's Avatar
DoC
Is this the Warhawk LSX setup that you're replacing your "inlet" rockers every 3,000mi?
Greg,
Why do you think the screens will affect oil movement at all? If oil filters can flow the oil to feed your entire engine and are much more restrictive then a simple screen, why wouldn't the screen work fine?
Old Jul 31, 2006 | 09:07 PM
Greg Fell's Avatar
Filters are pressurized however.
Old Jul 31, 2006 | 10:09 PM
Haans249's Avatar
That is true, but I still don't think it'll affect oil flow, because the entire oil system is pressurized as well I think if you're not going to rebuild the rockers, that screens are probably a good idea. Do you have any experience with using screens and oiling problems? I've never used screens before so its just a guess on my part.
Old Aug 1, 2006 | 09:21 AM
ScottyRocket's Avatar
We use screens on SBC race engines all the time. No issues.
Old Aug 1, 2006 | 10:31 AM
NoRice's Avatar
yup all the way to 2,000 pro mod stuff run screens
weather you can run them on the gen. 3 or 4 stuff i dont know. but you guys are pushing new valve train parts to the max i'd think about doing something to keep the **** out of the short block
