Thinking of getting a LS2 427 in my c6
MTI in Houston would be doing the work.
MTI Stage 3 Ported & Polished Racing Cylinder Heads Includes: Ferrea Stainless Steel 2.080" Intake & 1.60" Exhaust Valves, Custom Double Valve Springs, Titanium Retainers, Custom Spring Locators and Extensive Port & Polishing Work Maximizing the Full Potential of the 427
g1 cam 228/232 lsa 113
UD pulley, 42 lb injectors
6800 redline
2 year warranty!
And if for some reason that doesn't give me enough power to keep me happy, then I'm thinking the engine will be strong enough to take a bit of boost or nitrous.
Anything else I should be thinking of?
That's a good idea for the Ls7 intake, but I'm hearing there is only a 10 - 15 hp gain over stock c6 intake. Hard to choke down $800 or $900 for that
Are the ls7 heads better than the stage 3 from MTI? http://www.motorsporttech.com/c6_engine01.asp
As far as who ever told you that the LS7 intake manifold only makes 10-15hp more then a LS2 manifold is retarted. First, the two intake manifolds don't even fit on the same head, and secondly, when flowed, the LS7 head/intake combo STOCK flowed 330+cfm. Good luck getting even 280 out of the LS2 manifold.
As far as choking down 800-900, how about basically cutting even once you get the ls7 manifold (~300) and LS7 fuel rail (129) and i'm not even sure you need it, LS7 heads (2500) for a total of ~3,000 and you've got way more power then the stage 3 combo and are saving money at that.
I suggest that you do a lot more research before you dive into this!
Best Regards,
Adrian
For second, there is only 1 place i'd fully trust to do that and that is by Steve D. @ RED
228 cam is too small, at least a 24x and that is still like a 224 in a 346.
LS2 427 stroker (RED)
AFR 225 or ETPs
FAST 90/90 ported by Tony Mamo @ AFR
a custom cam (I would go Ed @ EDC)
600rwhp in sight
AFR 225 or ETPs
600rwhp in sight
Best Regards,
Adrian
As far as research goes, that's why I am starting the questions now. I'm looking at doing this in the February / March time frame
AFR 225 or ETPs
600rwhp in sight
Nice! How much out the door, fully assembled, incl ls7 heads and intake, etc?
Best,
Adrian
