LS7 Spring Pocket Diameter?
Here is that link! Pick just about ANY spring you can find! You can go really large...
Best Regards,
Adrian
Best Regards,
Adrian
O.D.: 1.275"
Coil Bind Height: 1.045"
Spring Rate: 352 lbs/in
They come with titanium retainers and the seats for $300.
Here's another option to critique. The K-Motion K-750's (dual spring):
OD: 1.265"
Seat Pressure: 130
Open Pressure: 395
Spring Rate: 482
Coil Bind: 1.050"
The retainers for them are titanium, are for 7* locks, and add .050" to the installed height. You've had good results with the K-800's, so maybe these will work too. Hopefully they won't break any intake rockers
What do you think?
What about the good ol patriot golds?
As for the PP Gold's are you saying that any aftermaket LS1/6 spring will work on the LS7 heads? If that's the case, then my life just got that much easier. I was under the impression that spring in the LS7 heads should be beefy to handle the high lift and the 1.8:1 rocker ratio, so I was looking outside of just LS1 aftermarket springs.
I thought I read you were going to use ti valves? Are you using the gm's or ?
Thanks for the help Greg, much appreciated!
The PRC's would work good too.
Also something to chew on, custom thickness lash caps. Chris @ VAC Motorsports can get about any size you would need. You can get your valvetrain geometry dead nuts on that way. If its perfect with the LS7 cam (.590ish lift), it will be off on a higher lift. Cheap way of getting custom length valves.
