LS1-LS2 intake's
Old Aug 14, 2006 | 07:11 PM
Ed Parker's Avatar
Default LS1-LS2 intake's
What is the differance between the 2 and is there a differance in the
injectors (lb) on an 05 C6 LS2 and say a 2002 camaro ss.
Thanks
Old Aug 14, 2006 | 07:32 PM
viewsonic's Avatar
Thanks
lots of differences.... they are two totaly different intakes.... for one the LS2 as a 90mm tb opening... and is a different mold than the ls1 intake....
Yes they are different size injectors.... LS2 has 34lb/hr injectors...
Old Aug 14, 2006 | 07:50 PM
Ed Parker's Avatar
will the LS2 fit on an LS1? The reason I am asking is a friend is putting an LS1
in a 69 chevy pick-up and was wanting to try it on. I have no use for it any more And I could use the money to go towards a cam and a GOOD tune for the Maggie.
Thanks View
Old Aug 14, 2006 | 08:02 PM
viewsonic's Avatar
Thanks View
Yes you can put a LS2 intake on a LS1...
LS2 and LS1 style haeads are the same... So you can mix and match the intakes.
I have a LS1 (FAST 90) intake on my LS2.
There will be a few mods to make it work... (map sensor relocation, different o-rings on the injectors... etc.)
Old Aug 14, 2006 | 08:07 PM
Ed Parker's Avatar
Thanks, I let him deal with that. What's the going price for a LS2 intake and injectors with 8,000 miles on it? That is my last question.
for now.
Old Aug 14, 2006 | 08:37 PM
viewsonic's Avatar
for now.
If that includes fuel rails... I would say around $300?
Old Aug 14, 2006 | 08:40 PM
96whitez28's Avatar
I have a used LS2 Intake I can take $150 shipped to the 48 states if he's interested.. Sorry no fuel rails. And he wouldn't need different injectors just injector o-rings. The injectors he should match up to his engine combo not his intake.
Old Aug 14, 2006 | 08:53 PM
viewsonic's Avatar
ls2 injectors > ls1 injectors...
They flow more period.
Instead of buying new o-rings... which are expensive... whynot just invest in a cheap pair of injectors...
Also if you buy a complete LS2 intake with fuel rail you will not have to worry about adapting your ls1 rail to fit on a ls2 intake...
