How much difference is 14cfm?
Thanks for the help.
your heads with a ported fast 90 maybe able to flow to the full potential of the heads. the problem is that most intakes are not capable of flowing enough to feed these big CFM heads.
well it's already been provin that an ls7 intake can keep up with the ls7 heads with little work..GM finnaly grabbed there ***** this time and it shows.
Does anyone have an answer (educated guess) for his original question?
Unless they were done on the same bench, by the same operator, with the same orifice size, the numbers are meaningless. You can use them only as a "reference". I've seen numbers vary by much more than 14 CFM just based on the bench, the operator, and the test methodology.
Now, with that said, there is a rule of thumb in racing.
HP= CFM X 0.2575 X # OF CYLINDERS for hp potential
The lower the power per cubic inch the more accurate the equation becomes. If you have an extremely efficent motor, then the constant of 0.2575 has to increase.
That being said.
.2575*8 = 2.06 For Race motors, we use 2.15 for a Pro Stock Type motor its around 2.35. Keep in mind these are BALLPARK, and miss about 100 important variables.
310* 2.06 = 638.6
324 * 2.06 = 667.44
Delta = 28.84
Keep in mind you don't see nearly that flow through any of the current intakes. You have to lop off a significant ammount of flow.
That being said.
310* 2.06 = 638.6
324 * 2.06 = 667.44
Delta = 28.84
Soooo is it even gonna matter what heads he gets if lets say the intake he has only flows 300?
