Cam shaft for ls7 headed 441
i am building a 441 with ls7 heads. this motor will see a little bit of nitrous 150 -200 most. i do not drive this car daily, and i can handle a large camshaft as a cruiser (i had a 252-262 in a 408 before this). the motor is being built with 12.1 compression, i was thinking of something in high 240/low 250 intake side, and i would imagine 260+ on the exhaust side around a 110 lsa, i am just having problems finding the proper lift i want because of the 1.8 ls7 rocker. of course i am keeping this hydraulic, and combine with the ti valves i am running should rev to 7k easy. any help would be appreciated.
Ryne just put the special spark plugs in there...they can do everything you don't even need a cam....they will even wipe your ***. lol..you know what i say go big or go home....or go bigger.
Originally Posted by Ferocity02
Well, what do you want from the cam? Need to narrow down the possibilities a little bit.
Originally Posted by RyneZ06
more of a max effort kind of deal, i am thinking of going with 252-262 on 110lsa 644-655 int/ext, its a cammotion grind, thinking abut raising the compression to 12.5 gets my dynamic compression to 8.6 or so. this car will see lots of torco, or 100 octane, like i said i dont drive this car often
I agree, that cam is pretty big dude. For LS7 heads, you will want more split than that. I am running 18 degrees of split on mine. Katech's torquer cam has 24 degree's of split. That cam will struggle down low, and the driveability won't be that great.
note: both cams shown with 1.7 rocker lift, 1.8s will make .624 lift.
LS1 Tech Administrator
Both recommendations are excellent. I like the second cam choice a little better since this is a 441. If I were to change anything, I might narrow the LSA to 112 knowing the larger displacement will make the LS7 heads a little more undervalved.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
LS1Tech Premium Sponsor
WOW, that's an old thread!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
