whats this set screw called?
Old Sep 26, 2006 | 08:32 PM
silvergeeteeoh's Avatar
Default whats this set screw called?
hey guys. looking under my car today and saw a little bit of residue next to this pair of set screws. kind of curious of what they are since im not familiar with the location. they are on an LS2, 05 GTO. driver side. about 6" in front of the engine bell housing/transmission seam.
the one that is leaking slightly i believe is slightly backed out farther than the left one. its an allen headed screw. and i wanted to make sure it wasnt loctite'd on before turning on it with a allen key.
heres a pic:
thanks for any help!
Old Sep 26, 2006 | 08:36 PM
crazymofo1986's Avatar
**** EDITIED ****
I would recommend that it may not be the best course of action to make changes to something that is not defective.
Old Sep 26, 2006 | 10:02 PM
WOW!
Thanks for the insight. You must be full of Kuh-Gnall-Edge.
Stop wasting space, if you dont know - dont post.
its that simple.
Old Sep 26, 2006 | 10:42 PM
****EDITED for content and grammar****
Why would you take out screws of something you have no idea about? There are many things can go wrong. It could be a piece thats not supposed to be taken apart. Or it may need to be torqued to a certain specification. It might have vaccum or fluid behind it. My advice would be to not disturb it.
Old Sep 26, 2006 | 11:25 PM
Slo_240sx's Avatar
Crazymofo, if you arent here to help then dont bother taking space like he said. And like he said, since you obviously cant read his second paragraph that the set screw is LEAKING.
Onto the note of helping him FIX HIS PROBLEM, take the screw out, dab some thread sealer and screw it back in, thats if you can get to it. Those screws go into the ports that feed the sump. If you were to look in the pan you would know what I mean. It has a rail that comes from the front to the back since the filter is relocated in the front on GTO pans.
Old Sep 26, 2006 | 11:39 PM
"well y the hell would u take out screws of sumthing u have no idea about"
unreal, what a moron. Open your uneducated eyes and READ for crying out loud.
I was never going to "take them out", since when is "turning on something", taking it out. Find another thread to be negative on. You must have amazing social skills, what a great fellow human being you are ****. Go try to boost your post numbers somewhere else.
240sx, thanks for the info. I was under the car checking after a recent oil change, thats when I saw the residue, not burnt on, but fresh. Felt it, it was oily, so decided to snap some shots and see if anyone could identify it as a problem. I will check it out in more detail tomorrow, and post an update. Thanks again..
Old Sep 27, 2006 | 02:45 PM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Edited for utter stupidity....
Old Sep 27, 2006 | 06:48 PM
mr2guru's Avatar
Take them out, dab some thread sealer on them and put them back in.
You can use those ports as an oil pressure reference also. They just run via hardline inside the pan to the front oil filter.
Old Sep 27, 2006 | 07:42 PM
thanks for the help, I will monitor it over the next couple of days and see if where I wiped away, more collects - then I will attempt the thread sealer.
