LS7 and LS6 Cam and Crank pickup and sensors
I was wanting to get some details on the cam and crankshaft position sensors and the part numbers for the LS6 and LS7. I have read several several threads on this but I figured I might cut through the chase and get the part numbers if possible.
I would need the part numbers for the electronic sensors and the gears that provide the signal.
Thanks for any help.
OK, I think I found some info.
GM crankshaft reluctor wheel:
#12559353 - 24X reluctor wheel. Available.
#12586769 - 58X reluctor wheel. I can't figure out how to get one of these.
Crankshaft position sensor:
#12560228 - Available.
Camshaft reluctor for LS6 ? I have read that this is on the "sprocket"? I am guessing this means the timing gear? Any help would be great.
Camshaft position sensor. I would like to get this part number as well. Any help would be great.
Thanks to wrencher for this waveform info: (clarifying the cam sensor designates intake/exhaust phase and the crank waveform designates phase timing)
https://ls1tech.com/forums/showthrea...osition+sensor
Any help with purchasing these items would be very helpful.
Thanks.
Thanks.
