Warhawk LS7X 12deg.
Old Nov 1, 2006 | 09:18 AM
  #41
Stang's Bane's Avatar
Yes they will, however according to RobinL you can only use the standard 4 head bolts, the extra two will not line up. If you want to use the extra head bolts, you must use the Warhawk block. As far as I know!!
Old Nov 1, 2006 | 09:32 AM
  #42
AppleMac's Avatar
then what are the extra 2 bolts for on the GMPP block if there is not a head that can take advantage of it?
Will GMPP be making heads for the new block?
Old Nov 1, 2006 | 09:33 AM
  #43
gator's 99TA's Avatar
there will be 6 bolt heads once the blocks are made.
Old Nov 1, 2006 | 10:13 AM
  #44
AppleMac's Avatar
awesome
Old Nov 2, 2006 | 03:31 PM
  #45
DanZ28's Avatar
Subsribing. Interested in the out of box flow numbers.
Dan
Old Nov 2, 2006 | 10:07 PM
  #46
FormulaFire's Avatar
I'm interested as well. Should be interesting to say the least
Old Nov 6, 2006 | 08:23 AM
  #47
ScottyRocket's Avatar
Please tell me these are going to flow over 370 cfm out of the box......fingers crossed!
Old Nov 6, 2006 | 08:57 AM
  #48
I would be happy with over 350 . AND a better than factory ls7 exhaust flow. I think these will be a porters dream. For the price, I don't think they can be beat. Even at 350 the intake is still gonna knock them down a good bit.
Old Nov 8, 2006 | 09:59 PM
  #49
corvettetimmy's Avatar
I realized today that the flow numbers dont matter any more. The F-1 procharger will pick up the slack.
Old Nov 10, 2006 | 09:59 AM
  #50
Yea, but for our NA application, flow does matter.
Old Nov 11, 2006 | 05:43 PM
  #51
Damn right!!
Old Nov 17, 2006 | 08:34 AM
  #52
any flow numbers yet?
Old Nov 17, 2006 | 11:53 AM
  #53
MerlinPro's Avatar
Collections Removal
Stang,
A very fair question and here's where we are now.
The head you see at the top of this thread has been tested as follows:
350/250 @ .700. The head was assembled and tested as it came in the door, as-cast, no bowl blend, porting or back-cut valves- basically nail heads. The numbers were still climbing at .900. This head will want big cams.The results directed that we relocate the valve job slightly-which is happening now. We should have a new test sample head next week with the adjustments, then we'll test again. I'll post if it happens or not to keep you up.
Almost forgot-I'm told we'll most likely change spec from 2.20 x 1.625 to EITHER of 2.275 OR 1.650. We'll test to confirm.
Thanks for asking.
Old Nov 17, 2006 | 02:04 PM
  #54
There is a God!!!
Not sure what i would be doing at .900" but either way, i like it.
Old Nov 18, 2006 | 09:49 AM
  #55
383ss's Avatar
Originally Posted by MerlinPro
Stang,
Thanks for asking.
AWESOME, thanks for the up date!
Old Nov 18, 2006 | 01:28 PM
  #56
Merlin, thanks for the results. If you go to the bigger valves will the minimum bore size still be the same? The reason I am asking is that I am limited to a 4.11 bore and I really want to use these heads. I feel at this point my greatest bang for the buck will be with these versus GM ls7's and the ET LS7's. I am especially encouraged by the exhaust flow. Won't need as big of a split on my cam.
Old Nov 20, 2006 | 08:37 PM
  #57
C Murda's Avatar
so i take it these heads arnt out yet?
Old Nov 20, 2006 | 09:56 PM
  #58
SDB's Avatar
SDB
with porting should be in the 400-406 range at .700 lift I assume, like LS7 heads? Full race stuff obviously...street oriented, maybe 370-385 intake and hopefully 250 exhaust with no pipe?
SDB
Old Nov 20, 2006 | 10:03 PM
  #59
Tuf-Titan's Avatar
Is it safe to say these heads will be out for the market say mid Dec?
Old Nov 21, 2006 | 08:31 AM
  #60
MerlinPro's Avatar
Collections Removal
If the valve-job relocation and increased valve sizing test well next week, more like Jan.
