Iron 408 in LS2 based vehicle???
My current setup is as follows
05 6.0L ls2 (24 tooth reluctor (SP?) wheel)
HPE S-Cam (238/242, .608/.612, 113 LSA) - will be re-used (might be a little small???)
HPE Stage III 5.3L heads - will be re-used (might be a little small???)
Now my plan is to install an iron block 408 (LQ9 block I think) over the winter. I plan to install an assembled short block from one of the sponsors (undecided as to who) and plan to spray a small (large) shot of N2O. A ported fast 90mm instake will also be added to the setup.
Now here come my questions,
What sort of issues will I run into, I have seen many posts of people putting in LS2 engines into LS1 based vehicles but nothing the other way (From what I understand the LQ9 is close to an ls1 block).
1, Knock sensors, does the iron block have a spot to install them on the sides like the LS2, or should I use the sensors in the valley cover (meaning purchase an ls1 valley cover)?
2, front and rear covers, can I re-use my current ones from the LS2 or not (I believe the cam position sensor is on the front right now, will I need to relocate it to the back like on the LS1's)???
3, Oil pickup - I think I recall reading that the LS1 pickup is longer (???) does that mean I can re-use my current one or not???
ANYTHING ELSE that anyone can think of???????
Like I said I appreciate any and all input.
I am also planing to spray a pretty decent sized shot of nitrous and want the extra strength that the iron block will offer - I know this has already been discussed many times before on here.
The plan is actually to put my existing LS2 into another vehicle (my truck) once I am done so it wont be going to waste.
Thanks for the responses
