L92 flow results with manifold.
Old Nov 4, 2006 | 04:14 PM
Richard@WCCH's Avatar
They look like a one piece intake. I don't see how or where you could separate these manifolds.
Richard
Old Nov 4, 2006 | 05:01 PM
Beast96Z's Avatar
Originally Posted by 2c5s
Marginal......... looks like the intake flow numbers equal cathedral port numbers with no intake. My L92 and L76 are ordered.
I think there's going to be a bunch cathedral port door stops laying around in the near future.
Bout 20 cfm, I would consider that marginal I guess. Far from "drastic", but how can you argue over something with no set limit?
Old Nov 4, 2006 | 07:21 PM
Wnts2Go10O's Avatar
Richard
flip the manifold over and youll find 2 metal rivets, those arent there for show
Old Nov 4, 2006 | 10:06 PM
zigroid's Avatar
this just made my decision of choosing between an L76 manifold or an L92 carb style manifold even more difficult.
323 cfm through a manifold
do you know how much did the 4.1" bore help over a 4" bore?
Old Nov 4, 2006 | 10:10 PM
I don't see a separable seam around the manifold like the LS7s. Where is the intake supposed to split?
Richard
Old Nov 4, 2006 | 10:49 PM
Wnts2Go10O's Avatar
Richard
well lemme go look at it more closely.
Edit: well thats weird as hell. theres 2 posts in the intake that make it look lik a 2 piece. it doesnt seem like the intake needs them for rigidity but yea there is no seem
Old Nov 4, 2006 | 10:54 PM
machinistone's Avatar
Those are some nice numbers.
Old Nov 4, 2006 | 11:31 PM
Methinks GM might have put the 2 posts in to hold all the boost pressure!!!
Richard
Old Nov 6, 2006 | 12:27 AM
nitsudls1's Avatar
Will these heads/intake work on a ls1(5.7) block. The intake size lookes to be on the big side. Has this been done before?
Old Nov 6, 2006 | 01:05 AM
SStrokerAce's Avatar
No, they need at least a 4.0" bore.
Zigroid,
A well ported single plane should probably do BETTER than that!!
Bret
Old Nov 7, 2006 | 05:13 PM
dame's Avatar
I'd like to know this as well....... im sure some of our head gurus (maybe even Mamo himself) could answer this for us.
Old Nov 9, 2006 | 09:53 AM
  #32
DogNutz's Avatar
How much is it for your head porting/clean up work on these heads?
Old Nov 9, 2006 | 10:19 AM
  #33
MrDude_1's Avatar
the floor of the intake vibrates without it, and it can make the intake fail.
i believe i read that in Will Handzel's book "How to Build High-Performance Chevy Ls1/Ls6 Engines"... but it could have been another book.. i forget...
Old Nov 9, 2006 | 10:45 AM
  #34
StreetnStrip's Avatar
Closed ex-Sponsor Account
we got ourselves a booknerd.
Old Nov 9, 2006 | 01:12 PM
  #35
NemeSS's Avatar
on a ls1 intake i had i drilled out the 3 pillars and cut out the bottom, the polished the runners and any rough surfaces and epoxied evrything back together, never broke or leaked, even made over 550 rwhp with a turbo
so i dont think it will affect it to much if they removed, but then again
