How much timing is your 402 on.
Old Nov 9, 2006 | 06:08 PM
Kounsy's Avatar
Default How much timing is your 402 on.
Just like it says, i want to know how much timing is on your 402.
Mine is pulling 18 degrees. If its at 20 or more, it starts rattling the valves, can anyone point me to the right direction.
Thanx,
Bobby
Old Nov 9, 2006 | 07:36 PM
V6 Bird's Avatar
Thanx,
Bobby
Study the cam and where peak torque should occur at. Get the A/F set to around 12.2 up until that point to keep the rattle quiet. Run a good plug...IE not a TR6...4554 are what i like to run for NA tuning...
start with a safe amount of timing with a fatter A/F ratio...once you get past peak torque which is also where VE occurs at 100% then you can increase timing 2 degrees after peak torque to gain hp...When the car starts falling on HP after each 2 is added then back it up to where the last setting was at....Every head is different, every combo is different. A proper tune in a fuel injected motor will never have a flat line A/F curve. I like to increase timing after peak torque simply because you are no longer at pure VE (volumetric efficiency)...your VE generally fades to say 80%or less and you can get away with running more timing..to help burn the extra fuel that nots being used up...reading your plugs is a great way to see this. WB 02's dont tell the whole story of whats going on in a motor...they get close...
Old Nov 9, 2006 | 08:33 PM
Kounsy's Avatar
i appreciate the input. I am running a tr6 plug. I havent had it on a dyno yet, which it prob would help though. I have a prc stage 2 ls6 cnc ported heads with a 250/258 .580 .580 on a 108lsa. I understand each head is differ, but i never seen the timing so low on one. Do u think it needs more octane?
Old Nov 9, 2006 | 08:36 PM
ONEBADWS6's Avatar
I run a TR6 plug, I also run 27*
Old Nov 9, 2006 | 08:39 PM
Kounsy's Avatar
well when the timing is at like 25 or so, and you get on it. It will start pulling hard then drop off around 4-4500 to like 6000 then start pulling hard again, and with that the valves are rattling? i dont understand
Old Nov 9, 2006 | 08:44 PM
ONEBADWS6's Avatar
What compression are you running? What fuel are you running? Is anything on the car rattling? I need more info.
Old Nov 9, 2006 | 08:50 PM
Kounsy's Avatar
93 octane. Scoggin Dicky's built the 402 with a -14cc dish piston. The heads were cut to a 61cc (which were suppose to be 59cc) the comp. is suppose to be 10.9.1. PRC stage 2 heads, fast 90, NW90, 42lb injectors, 1 7/8 hooker headers. 250/258 .580 .580 lift, and 108lsa. running a 3500 tci converter with a turbo 350 with stock 3.42 gear.
Old Nov 10, 2006 | 12:16 PM
ONEBADWS6's Avatar
Well first try running 100oct fuel to see if that makes the knock go away. If it does get that thing on a dyno and tune it as it should run fine on pump gas. You just have to go step by step and go through everything.
Old Nov 10, 2006 | 12:19 PM
SideStep's Avatar
Thanx,
Bobby
How much oil is it using???
Old Nov 10, 2006 | 12:48 PM
SLED28's Avatar
What do you mean by rattling?? Pinging? BTW, why you using such a small cam
Old Nov 10, 2006 | 06:44 PM
Kounsy's Avatar
valves rattle on upper rpm. Using qt. every 800miles. Why do u ask such a small cam.
Old Nov 10, 2006 | 07:10 PM
SLED28's Avatar
Just kiddin around. Are you floating the valves? I think your best bet is to call your engine builder up.
Old Nov 10, 2006 | 07:45 PM
ONEBADWS6's Avatar
You should not be using any oil. Your pcv is sucking it into the intake and lowering your octane and causing the knock.
Old Nov 11, 2006 | 10:18 AM
slow trap's Avatar
that is a very good posibility and what i would think it is also.
Old Nov 11, 2006 | 02:45 PM
Kounsy's Avatar
i am running a breather and got rid of the pcv system
