Patriot Xtreme Gold Springs Have Arrived !!
Old 11-16-2006, 01:26 PM
Gunnar@Patriot's Avatar
Default Patriot Xtreme Gold Springs Have Arrived !!
We just received our new Patriot Gold Xtreme Springs. Guys these look great and turned out just as we designed them. We have tested several of these and the pressures are right on the money... 155 @ 1.800" and 410 @ 1.140".
As you can see from the pics, the outer spring is Patriot Gold while the inner spring is a polished silver. These springs have been specially designed for the needs of the LS community. They were designed and manufactured from chrome silicon vanadium material with proprietary thermal process. For our customers who wish to upgrade from our Patriot Gold springs, all that will be needed are the springs. Your current hardware will interchange. We do have several thousand in stock, but please get your orders in quickly. These are selling at a rapid pace (many to other head porters).
The Patriot Gold Xtreme series is of the same high quality of our Original Patriot and with added performance for more aggressive cams, boosted applications, etc.
Attached Thumbnails Patriot Xtreme Gold Springs Have Arrived !!-patsuper-spring.jpg
Old 11-16-2006, 02:51 PM
SSilverSSurfer's Avatar
they look awesome, whats the max lif those can handle?
Old 11-16-2006, 02:58 PM
9 Second Club NA
Dragaholic's Avatar
I believe .660" is what they last posted when they first posted about them.
Old 11-16-2006, 04:21 PM
WKMCD's Avatar
How much?
Old 11-16-2006, 04:34 PM
The max lift is .660".
We do have a special on this kit through the end of this month for $239.50.
Old 11-24-2006, 09:25 PM
sr71's Avatar
great. a little more spring pressure would be good for us fi guys with larger cams.
Old 11-24-2006, 10:54 PM
9 Second Club NA
Dragaholic's Avatar
Do you have to purchased direct to get that pricing or can you go through one of your dealers?
Old 11-27-2006, 01:11 PM
Either one.
Old 11-27-2006, 08:18 PM
Louis's Avatar
Whats coil bind?
Old 11-27-2006, 08:30 PM
9 Second Club NA
Dragaholic's Avatar
Hrmm...what to do, what to do. I want to purchase a set of bare L92 heads, this spring kit, and a set of rockers (8 L92 intake/9 LS1 exhaust). Then see what companies offer what. Then if I like what's out there, then I could sell the parts. If not, then I have parts to work with. What do you guys think?
Old 11-28-2006, 12:47 PM
NemeSS's Avatar
what is the od of the springs?
Old 11-28-2006, 01:48 PM
gun5l1ng3r's Avatar
Are the inner springs on all dual-spring set-ups not even with the outer springs?
What I mean to say, is the inner spring supposed to shorter and not centered in the outer spring?
Old 11-28-2006, 08:38 PM
jdo6696's Avatar
just got mine today, thanks Gunnar.
Old 11-29-2006, 09:24 AM
1.300" O.D.
Old 11-29-2006, 09:26 AM
When they are uninstalled, the inner spring will not be even with the outer spring.
jdo6696- Glad you like the springs. Thank you for the order.
Old 12-08-2006, 10:16 AM
DogNutz's Avatar
Thanks Gunner!! BostonHatcher and I want to thank you for giving us the extra time to come up with our money to purchace the springs! You are so great to work with!
Old 12-08-2006, 08:14 PM
fourplay's Avatar
Gunnar,
Not sure if this has been asked but how much longer till you offer different L92 packages? Also can you give us some basic info i.e. porting, millin, springs used etc.
Thanks ahead of time
Old 12-09-2006, 01:13 AM
Bring the Noise's Avatar
Originally Posted by fourplay
Gunnar,
Hmmm I asked that same question a couple of months ago.
The response back then was the Predators are taking priority in the R&D section of Patriot and once they are/were done then Patriot would look at an L92 head design.
Now back to the new springs...
Will the new .660 extreme's become the standard on your 5.3L and/or LS6 assembled head packages (say in 07).
Or will you keep the old .650" Golds in the packages and have the .660" extreme's as an option for the guys that are looking to run max lift cams?
Old 12-11-2006, 12:43 PM
The Orginal Golds will come standard and the Xtremes will be available as an uprade for $25.00. We have been working on the L92. We are hoping to have some programs ready after the first of the year. We have many new projects going on...Predator heads, L92's, our new SBC Freedom series, 3 Valve Ford, SBF, BBC, etc.
Quick Reply: Patriot Xtreme Gold Springs Have Arrived !!
