Tsp 427
ur TSP 427 cid LS7 short-blocks offer the best durability for the best price possible! GM's new aluminum LS7 block debuted in the 2006 Corvette ZO6. It comes from the factory with a 4.125" bore, and it will accept the same timing cover, rear cover, valley cover, timing set, and lifter trays as the LS2! Our standard short-blocks come fully-assembled using an Eagle 4.00" stroke crankshaft, Scat H-beam 6.125" connecting rods with upgraded ARP 2000 rod bolts, and Diamond Racing 4.125" flat-top pistons with -3.8cc valve reliefs. The price listed also includes the appropriate timing cover with camshaft position sensor, valley cover, rear cover, lifter trays, standard LS2 timing set, and the necessary cam sensor and knock sensor harness extensions to retrofit it into an LS1 vehicle! We offer many upgrades for our short-blocks, and we will custom-build one for your application! We try to keep a few 427 cid LS7 short-blocks in stock, and if you order one of our in-stock short-blocks it can ship as soon as the next business day! Our LS7 short-blocks also include the engine crate, engine cradle, and truck freight shipping charges within the continental United States! We can also assemble your short-block with your choice of camshaft, new camshaft retainer plate, and ARP retainer plate and timing set bolts for an additional $399! Feel free to give us a call, and we will help you select the parts that will best suit your application. You can also call us to check if any of our engines in stock will work for what you are looking to do! All short-blocks will be built using the 2005 and older 24x tooth reluctor wheel on the crankshaft. If you have a 2006+ vehicle that you will be installing our engine in you will need the updated 58x tooth reluctor wheel! BE SURE TO SPECIFY IF YOU NEED THE NEW RELUCTOR WHEEL WHEN ORDERING!
LS7 vs resleeved LS2 is debateable maybe if you exceed 1000rwhp the resleeved maybe stronger. there are actually a couple of very debatable threads going on.
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
YEAH, waiting to get the pricing on the longblocks!!
From what I have been told it will be going up. They actually discounted the total cost of the shortblock over 2k to get that price. I have been looking at a 427 for months and have several estimates and I am jumping all over this because it is the best affordable package out there. Granted other companies may use a little more expensive parts (doesn't make it better imo) They have everyone beat on this deal.
Yes, they also degree the cam and check p to v as well. I have been beating this guy up for over a week with questions and e-mails and he took the time to help me out and I feel very comfortable with TSP building this motor. I have never dealt with TSP before this, I have always heard great things about them and once I saw the price I had to check it out.
